Problem HDS Spindle making noise after shaft kit replacement
Results 1 to 7 of 7
Thread: HDS Spindle making noise after shaft kit replacement
    Feb 2007
    Default HDS Spindle making noise after shaft kit replacement
    Wondering if anyone has experienced the noise I have with my HSD 929 spindle. I have just replaced it with a new shaft kit so the bearings should be fine. I did notice that with the old shaft that there was a similar sound at start up/warm up but then it would disappear. This leads me to think that there is an issue with the housing unit. The sound is quite tinny and sounds as if something is loose (at the 30 second mark of the video it seems to correct itself slightly) but I've refitted to make sure that all bolts are secure so there shouldn't be a problem there.
    Any advice would be greatly appreciated.
    Cheers
    Service SCM BR
    Guest
    Default Re: HDS Spindle making noise after shaft kit replacement
    Where is the spindle? I,m in Brazil.
    Via iPhone of the Tapatalk
    Member mactec54's Avatar
    Jan 2005
    branchy
    Do you have the correct amount of Grease in the Bearings, too much Grease can cause noise's at start up
    Mactec54
    Jan 2007
    that sharp noise at start,,,, little weird..
    like a washer loose and getting up to the speed.. im not saying anything were loosen.. I just try to say an example..
    by the way, what rpm it has on the video?
    Jan 2005
    Quote Originally Posted by victorofga View Post
    That's the noise a Bearing can make when it is skidding, from having to much Grease in it, or the Bearings are to tight a fit in the Housing or on the Spindle Shaft, It most likely is to much Grease, because the noise goes away, after it has pushed the grease out
    Mactec54
    Member joeldouglas's Avatar
    Dec 2018
    Hey mate,
    Did you ever solve this issue? i have the same router (procam mityboy) and the exact same problem.
    Any help would be appreciated,
    Cheers,
  7. #7
    Jan 2005
    Quote Originally Posted by joeldouglas View Post
    Hey mate,
    Cheers,
    Don't hold your breath for a reply this was posted in 2014 5 years ago you may be better off to start a new Thread
    Mactec54
