I have an SCM Record 2 and it has a NUM 750 control, I am told that there are some differences in the types of controls, what are you after and I can probably assist
chris f
hello
i need help on how to deal with num750,where i have french handbook but i need english manual.
and i need help in where i can find english manuals for operating and programming SCM router.
chris f
you have scm - num 750 -- if you working in wood I have the same - Iam in EGypt - Cairo - Elopoor
Thanks mr.Omar Sanad
yes i am egyptian and work in company near (6th october)
please send me your phone or send me mail on
ahmedsamy_81@yahoo.com
to take about how we can share informations
i need help for how i can obtain the english version for Num 750 handbook?Originally Posted by flinty
and for my first program i face a problem in the tool change , where the magazin is rotatig contiuously without stop when the program start in toochane cycle, how i can solve this problem?
The tool change should be standard ISO programming that is for example
T1 M6 for tool 1 M6 to change the tool.
To try this out in MDI (manual mode) you select MDI mode
and key in
T1 M6 and LF ( enter) and CYC start.
BUT you must press the cycle start key 4 times to action the command.
You can also try entering M12 which should rotate the tool changer to position 1 after a full rotaion, or M15 which will move it 1 position.
If you email me directly ( click on my name flinty above and send private email)( tell me what CNC machine you have) and you have a broadband connection ( for big file size).
I will email you copies of programs which have tool change in them as well as a lot of NUM information and I am sure we can get you going easily, I am also happy to give you a copy of my post processor which is written for NUM750F and Mastercam Version 9
thanks ror your quick reply
but can u send for me any help for num750 programming and operation in english
yes but I need you direct email address because I do not know how to attach files on the zone
chris
my email address ahmedsamy_81@yahoo.com
another note when i press MDI how i can write
T1 M6 or M12 while the screen don't allow me to do that?
When will you send me the files?
I have a full set of Programming and operating manuals Xeroxed for you as requested.
Please let me know when you are going to pay for them and I will ship as soon as I get your address from you.
chris f
Hi, I have also a SCM Record 2 with a NUM 750 control for woodworking. I am using Alphacam 2004 and I need postprocessor for NUM750. Is there anyone out there that can help me ???
As mentioned above previously, I have a full set of the works manuals for this machine that I prepared for the SOB alchemy who then did not buy them.
They are available for US$150.00 if you want them, because that is what it cost me to get them made.
Now regarding your problem, I assume you have a legal copy of the software, and if so your supplying dealer can give you a post.
I can obviously give you a Mastercam post which will run the machine perfectly, but it will not be understood by Alphacam.
So how to fix this dilema is either you get the manuals and develop your own post from the programming manual so that your software knows what detail to put in the post.
Or as said above go to Alphacam direct.
Or Buy a copy of Mastercam Mill and I will give you the post.
regards
chris f
Found these.
I have manual for num 10XX
Maby it is same, maby not
http://rapidshare.com/files/88139170/progmwen.pdf
http://rapidshare.com/files/88140838/opermwen.rar
Hello,
i need handbook for for Num 750 and advice. Reference did not starting.
I spent half a day staring at mine and all it was was speed control knob set to zero :/
internal fuse? no errors flashing on relays?
