Hello.
(1)
I have problem with lost UTILITES on NUM-750 (machine REALMECA-C200V),
such as at post#35 (from ramley,03-21-2011) here--> http://www.cnczone.com/forums/commer...tml#post915257
Startup screen is similar to:
And I have tape-reader with lost tape coming with this machine.
I don't know is it possible to use the set of utilites from another NUM-750 CN control (parameters no, of course).
If its possible - I needed in binary utilites files
(e.g. UT00.BIN,...,UT13.BIN as described at http://www.num-usa.com/EN_Tips/INTRE...tilityLoad.pdf).
(2)
After that - lost parameters on this NUM-750 REALMECA-C200V. Backup tape is missing (lost).
Situation like as at post#37 (from Badlo,05-12-2011) here--> http://www.cnczone.com/forums/commer...tml#post939765
Please help with detailed parameters manual and/or backup disks/files for this machine (NUM-750 REALMECA-C200V).
(Backup/Restore procedure described at http://www.num-usa.com/en_tips/intre...up_Restore.pdf)
On original NUM-750 cnc software disks must be present all of this, including utilites from above(1).
Thanks for any help.
