Does your turret usually unclamp to turn ? If so, it could be it's not properly unclamped and can't turn. It looks like there is an overcurrent because the turret is jammed and not referenced for the same reason. When you re clamp the turret the drive disables so error goes away.
I would check the turret clamp/ unclamp first.
