Colchester 2000L Parameters
Results 1 to 7 of 7
Thread: Colchester 2000L Parameters
    Default Colchester 2000L Parameters
    i accidentally changed batteries with the machine off and have lost all parameters and diagnostics on our lathe.
    Could anyone please help me with this as its our only lathe and need to get it running...
    Its a Colchester 2000L
    Mch No : L2150GFBSA/01680
    It has an 8 station Duplomatic tool turret.
    Please any help with this would be greatly appreciated.
    Brent
    Flies Fast Superman's Avatar
    Dec 2008
    Antarctica
    Default Re: Colchester 2000L Parameters
    I put something in a thread 5 years ago
    ... search for a thread titled "colchester 2000L"
    Thank you , i did enter it all. were a few changes i had to make but so far so good, only problem now is my Tool station doesnt stop rotating if i try to index it.
    Would you know the correct diagnostic code for an 8 station duplomatic tool turret?
    Dec 2008
    Antarctica
    Machine is long gone now... one of the guys was shifting it's location by crane, but slung it badly & dropped it. Broke a couple of items, oil pump & I think one of the boards in the cabinet.
    I'd bypass the turret by setting D500 to all zeros, get everything else checked
    Your turret problem could be one of the positioning switches for the turret. Or some procedure to set the turret "home" position ( just thinking out loud here)
    Other than that, can't help further, good luck
    May 2016
    United Kingdom
    Brent messaged you its nothing to do with parameters I work on thise all the time
    Quote Originally Posted by mbservice View Post
    Hello, can you send me a message and I will help you install parameters?
    salihakhan@turkuazmarine.com
  7. #7
    Merhaba e-posta adresinizi verebilir misiniz? a90 parametresine ihtiyac?m var.salihakhan@turkuazmarine.com
    - - - Updated - - -
    - - - Updated - - -
