Re Colchester 3000 L lathe Fanuc OT A control 910 911 alarm
Results 1 to 4 of 4
Thread: Re Colchester 3000 L lathe Fanuc OT A control 910 911 alarm
    Member PC3060's Avatar
    Jun 2019
    Default Re Colchester 3000 L lathe Fanuc OT A control 910 911 alarm
    Hi recently bought Colchester 3000 L short bed Lathe Plugged in turned on Program displayed could not go to anything else x z key pad flashing alternately batt lift displayed. Shut down replaced batteries Then turned on and got 910 parity low Tried to reset then showed 911 parity high error Screen shows 600. 06 then goes to 910 alarm Tried turn ing on with delete Cancel buttons pressed just comes up with alarm error again can't get past error code display Bought secondhand main board installed,it but still same error . Anyone got any solution
    May 2016
    United Kingdom
    If you changed the batteries when the power was up there is a high probability that you have contaminated or lost your parameters and require reload
    Jun 2019
    Default Re: Re Colchester 3000 L lathe Fanuc OT A control 910 911 alarm
    Hi yes that's right can't get past error parit high parity low 911 910 screen that is all it shows I was wondering if it alternates between high /low could the sdram be dodgy ?
    May 2016
    United Kingdom
    I'd clear all and reload where abouts are you ?
    Please pm me for instructions how to reload
