Need Help! Colchester Tornado 200 Lathe parameters
Results 1 to 14 of 14
Thread: Colchester Tornado 200 Lathe parameters
    Mar 2018
    Colombia
    Unhappy Colchester Tornado 200 Lathe parameters
    Hi guys, somebody has parameters for Colchester tornado 200, one of the ROM memories fail and everithing is gone. Please help.
    Mar 2018
    Colombia
    Default Re: Colchester Tornado 200 Lathe parameters
    Controller is Fanuc O-T and serial number is in the image:
    Colchester Tornado 200 Lathe parameters-whatsapp-image-2018-03-02-11-35-a
    May 2016
    United Kingdom
    have you resolved this ?
    *Registered User* DyrNarvaez's Avatar
    May 2018
    I have the same problem, somebody have the parameters
    I have a collchester tornado 200
    May 2016
    United Kingdom
    Quote Originally Posted by DyrNarvaez View Post
    Do you have the serial number
    *Registered User* ULM's Avatar
    May 2018
    Default Colchester Tornado 200 Lathe parameters
    C20177 ?. Thanks in advance. Can you help with parameter list for Tornado 200 with serial
  7. #7
    May 2016
    United Kingdom
    Quote Originally Posted by ULM View Post
    Yes please pm me your email
  8. #8
    *Registered User* moleda's Avatar
    Oct 2018
    I'm also looking for parameters to collchester tornado 200 (1995) serial C20251.
    Could you help me?
    Thank you in advance
  9. #9
    Dec 2015
    anyone can help me with sent me ladder in manual or .bin files. Colchester tornado 200 OM Controller.
    i have Parameters & diagnostics already.
    quick-cnc
  10. #10
    May 2016
    United Kingdom
    What does it say on the screen when you power up
  11. #11
    I have a similar problem with a Colchester Tornado 200, serial number C20385 from 1996. All the parameters have gone, tried to write them manualy (i have them printed) but the 900 parameters are all 0, i tried copy them from a tornado 100. Everything ok, no alarm but the spindle, chucks, turret comands are not working. Can someone help me with the parameters? And i read something abaout diagnostics, are those parameters too? Thanks!
  12. #12
    May 2016
    United Kingdom
    Hi Vlad
    Tornado 100 parameters will be close but not correct as there are different models and veraions of the machine you may cause damage to your drives please send me your email address in a private message and I will try and assist
  13. #13
    Member Tanay's Avatar
    Aug 2020
    Default Re: Colchester Tornado 200 Lathe parameters and diagnosis
    can anyone please help with Colchester Tornado 200 Lathe parameters and diagnosis.
    TIA
    Attached Thumbnails Attached Thumbnails Colchester Tornado 200 Lathe parameters-whatsapp-image-2020-08-12-1-29-a
  14. #14
    May 2016
    United Kingdom
    send me your email and serial number as not clear in picture
    There were different versions of 200 so would hate to send you incorrect ones
