Well, here goes... This part of the build is my greatest concern, seeing how I know as much about wiring a CNC cabinet as I do about classical woodworking... none.
Pictured in the top right corner is my 24VDC power supply for the Galil card. I plan on powering up a small bus/bank of 24V for my prox sensors, and relay cards.
The Servo drives will be positioned as shown, but with a 1" gap between each. Yaskawa recommends 10mm, and this will allow me to add 2 more drives in the future, when I get even more silly with this thang.
Below the servos, I am placing the CN-1 breakout boxes. These have cables that connect directly to the drives, and 48 (ea) terminals to wire up the encoder signals from the galil. I ordered 26-pin cables with flying leads to connect to the CN-1 boxes.
My intent is to have main power (220 VAC, single phase, 80 amps) to enter the enclosure in the top left corner. I have some power distribution blocks to channel the main power into the contactors and breakers for the individual servo drives. My thoughts are to keep the high current lines toward the top of the enclosure, away from the signal lines, which are situated toward the bottom of the enclosure.
I do plan on getting some DIN rail to mount the CN-1's, as well as my relay cards for my I/O requirements.
I have been advised by a few experienced builders out there to mount the VFD's (2 ea, 3.2 KW) in a separate enclosure. That is the plan for now, unless Al or Ger21 tells me otherwise
I have an ethernet jack in my wall right next to the enclosure, which runs across the shop to my control computer. I was origionally worried about noise in this line, but research on the internet tells me otherwise. Time will tell.
Airflow within this cabinet will be from bottom to top. The Galil board generates very little heat, and I wanted to protect it from the heat generated by the servo drives.
Please, if anyone is willing, let me know your thoughts on the general layout of my enclosure. I do not want to mess with the wiring until all components are safely bolted in the right place.
Also, frame should be here around the 18th of June. Sweet!!!!!
Thanks,
Rob
