Great job on this build, I always like to look back a see what other have built, Any updates changes to this build since then.
How the ATC holding up any info where sourced it from?
any info on the vender of the spindle or the brand name for the spindle?
Has anyone come across the drawing or schematic showing how the atc is controlled for tool changes, with a pneumatic solenoid and values & relays etc?
And how it wired to a bob?
I'm with eloid any info on the ATC workings macro's etc..........
Sorry to dig this post up from the graveyard but I have a question for @spoiledbrat: From the pictures and your setup, it looks like your machine should've been plenty rigid to be able to achieve higher acceleration rates but reading some of your comments on motor tuning and the jerky behavior of the machine, it seemed a bit confusing as to why you could not achieve that without sacrificing quality. Did you ever figure anything out on this subject matter? Did it end-up being the tuning procedure for your Yaskawa servo-drive/motor setup or something else?
Mactec,
I miss you. You are good people!
Pupdogg, I switched over to Industry Controls (a smoothstepper based board, from Kirk Brown. Once I did that, I was able to put the drives into Position mode. The Yaskawa drives have an autotuning feature, that calculates inertia of the system live, and sets appropriate gains/filters for best performance. I was able to get my machine up to 2000 ipm in the x and y.
Oddly enough, I am revisiting the tuning of the X axis. It seems to studder after small bump moves using the keyboard, and was showing evidence of under-damped response in some of may cuts (cut my first cabinet with it recently).
Problem is, autotuning will not work for a gantry, it is one servo at a time. I did learn, however, that Sigmawin+ software was updated, and it now has an "Autotune with reference" feature. When I tried to use it on my x axis (mach3 was jogging the gantry back and forth for me), the gantry motion started to sound very, very good. Crisp and solid, for lack of better description. However, before the autotuning sequence completes, the drive saturates (too much torque command), due to fighting the slower, not-so-well-tuned slaved axis.
I am about to attempt tuning again from scratch. I had my inertia set to 1000 (10:1), but after speaking with an engineer at my vendor, I was informed to start out at 0.325 (1045 lb gantry, divided by 32 ft/s sq, then reduced by square of gear ration (10:1 in my case).
If anyone on the zone has any insight into a solid process to go about tuning this beast (Yaskawa 1kw AC Servos), please do revive this thread and chime in. I know this machine is capable of much, much more performance than I had previously settled for.
Cheers!
Rob
back again, awaiting mod approval.
Sent from my SM-G892U using Tapatalk
So, Mactec, always good to hear from you.
I had been running the machine on an MCB-1, in position mode. since it is impossible to use autotuning using Sigmawin+ on a gantry, i basically found a setting that "worked" and left it be for a few years. now that i am cutting cabinets, i am retuning them now.
Turns out, i had the inertia ratio set to 10%, and i am now achieving far better resultd at 2.5%. I intend to do some experiments/bracketing to nail down the best inertia ratio (autotuning on single axis does this perfectly for Y and Z axis), and then proceed from there. I want my gantry to sing like my carriages.
Anyone having any advise for tuning sigma 5's in a gantry configuration, please chime in. I will post process and results.
Cheers!
Rob
