New Machine Build DIY- CNC Embroidery Machine - Page 81
Page 81 of 81 FirstFirst ... 317178798081
Results 961 to 965 of 965
Thread: DIY- CNC Embroidery Machine
  1. #961
    *Registered User* 2bobr's Avatar
    Nov 2018
    Default Re: DIY- CNC Embroidery Machine
    does the burn table need to be isolated from the tables frame?
  2. #962
    Jul 2010
    I have a Brother 416A 9 needle industrial embroidery machine that I picked up for a very low cost. The person I bought it from had been using it for the past 10 years and then one day it just stopped working. I am currently having the circuit boards looked at and repaired but they cannot guarantee that it will work when I get them back. I have inspected the mechanics of the machine and it is in very good mechanical condition. Even if when I get the boards back and it works I am still wanting to upgrade the electronics on it so it has more than just a 20X2 LCD display. Khalid will your Embroidery G-Code generator software work with the different features on one of these industrial machines such as switching from one needle to another or for the auto thread cutting and jump stitch cutting? If it does what would you recommend for the controller to control the steppers. I have built a few different 3D printers and use Marlin for the firmware but I'm not sure if Marlin would in this application. Any guidance you could provide would be greatly appreciated.
  3. #963
    Jul 2010
    Khalid, I showed your software to my wife who has been doing digitizing and embroidery for a while now. One of the questions she has is in regards to a multi-needle application. I read back and saw in a previous post that a macro would need to be used to switch from one needle to another. My wife showed me one of her digitized files that uses a color change as a pause in the stitch to do different things. For example sometimes a pause is needed to add other material to the design. This would use a color change to pause but would not actually change the color. Is there a way to specify what would be just a pause in the program versus an actual color change? Also as mentioned in my previous post is there a way to engage the thread cutter when doing a color change or even just a jump stitch? BTW I downloaded the latest version of your software and had no problems with the install or running it. Awesome work! I look forward to future enhancements. On a side note I think your software would be a perfect fit for breathing new life into older machines. I see so many posts from people that have older machines where the electronics have gone out on them but have good working mechanics but they cannot get them replaced because the company has discontinued that model as is the case with my multi-needle. Your software would allow them to add a computer and some newer inexpensive electronics and get their machines running again. Again awesome job and if there is anything i can help with on this project please let me know. I work on electronics as a hobby and am currently converting a regular table saw into a CNC table saw. Thanks again.
  4. #964
    Feb 2015
    hola para aumentar la velocidad de tu maquina debes cambiar el MOTOR PAP del volante de la maquina de coser por un MOTOR DC y controlar la velocidad con un PWM del mismo arduino y coloca un IR-SENSOR para verificar que este en la altura máxima la aguja de la maquina y ahí mandas el pulso para mover el pantografo en vez de coordenada Z solo así podrás aumentar la velocidad de puntadas de tu maquina así esta configurada la maquina BORDADORA ECLIPSE y HUBORDIX
  5. #965
    Member Khalid's Avatar
    Apr 2006
    Pakistan
    Quote Originally Posted by neodd70 View Post
    Dear,
    I abandoned development of the software however you can insert any M commands to run your macro at specified location. You can activate thread cutter with M command ( activate a relay etc).
    http://free3dscans.blogspot.com/ http://my-woodcarving.blogspot.com/
    http://my-diysolarwind.blogspot.com/
