New Machine Build DIY- CNC Embroidery Machine - Page 53
Page 53 of 81 FirstFirst ... 3435051525354555663 ... LastLast
Results 625 to 636 of 965
Thread: DIY- CNC Embroidery Machine
  1. #625
    Registered kiefer's Avatar
    May 2012
    us
    Default Re: DIY- CNC Embroidery Machine
    Quote Originally Posted by Khalid View Post
    This is how the modern embroidery machines as will as CNC machines work. In CNC machine this is called Rapid Motion without cutting. Whereas in embroidery these are Jump stitches. In embroidery softwares a minimum free travel length is defined for which they use Jump stitch. For example if the design has a length of Jump stitch that is 100mm and in software the Jump stitch is defined as 10mm then their will be 10 stitches in 100mm interval. Now if the distance is 9mm then there will be no Jump stitch.
    Yes, I know this, but in our case, machine makes huge jump, without stitches.
    In the file I sent you looks like this:
    line 1503 G01 X0.8 Y-20.2
    line 1511 G01 X2.7 Y17.8
    in this case, machine made the jump from -20.2mm to 17.8mm = 38mm!
  2. #626
    May 2012
    us
    in this file, they are divided nicely, about 6 mm each stitch, but we don't have Z axis to do anything.
  3. #627
    Member Khalid's Avatar
    Apr 2006
    Pakistan
    Quote Originally Posted by kiefer View Post
    So do you want me to add Z parameter in the lines!!!
    http://free3dscans.blogspot.com/ http://my-woodcarving.blogspot.com/
    http://my-diysolarwind.blogspot.com/
  4. #628
    Apr 2006
    Pakistan
    Here is the version 2.4.8 with minor changes as required.
    1- The machine will do some stitches at home location and then start afterward.
    2- Machine will do stitches during Jump.
    Please check and let me know if it works for you!!
    Attached Files Attached Files
  5. #629
    Apr 2006
    Pakistan
    For all the new comers, Here is the Setup file of the software. It tested in Windows 7 (32/64bit), windows XP...
    https://www.dropbox.com/s/lnpzfi6vha...rator.rar?dl=0
    I hope the program will run on your computer,however, if you find any trouble then install Visual Basic Run times files from:
    https://support.microsoft.com/en-us/vbruntime
    The M786 macro to be used in Mach3 software.
    Both the files are also attached herewith.
  6. #630
    May 2012
    us
    Good morning Khalid,
    I have new Gcode generator, and I saw how on the beginning makes 3 stitches without to move. I guess, this is exactly how it has to be. I'll try it with the machine a little bit later ( here is now 6 AM)
    Did you read my idea about multi head?
  7. #631
    Apr 2006
    Pakistan
    Yes Kiefer, The idea is great and you described it very well...Presently the GUI is too much cluttered, i have to make necessary changes in the software to increase its capability (including the multi-head) but first i want to see the video of the embroidery from your side (when ever you have time) that reflect the changes we have made in couple of days.........Now multi-head will be implemented only when someone has multi-head machine and volunteer to drive his machine with our software......
  8. #632
    May 2012
    us
    OK I just try the new version with the machine and everything works nice. However, I have a few technical issues with my machine.I might be able to make a video today.
  9. #633
    Apr 2006
    Pakistan
    Kiefer, I specially want to see the design in the hoop. I hope the design will be much cleaner due to the changes we have made in version 2.4.8.
    I will curiously waiting for the video.
  10. #634
    May 2012
    us
    Why the design should be better or cleaner?
  11. #635
    May 2012
    us
    I'm trying to make a new screen on Mach3 for this project
  12. #636
    Apr 2006
    Pakistan
    I think the first stitches at program start and the stitches between the jump stitches will release the tension in the thread. This is my opinion only.
