New Machine Build DIY- CNC Embroidery Machine - Page 33
Page 33 of 50 FirstFirst ... 233031323334353643 ... LastLast
Results 641 to 660 of 998
Thread: DIY- CNC Embroidery Machine
  1. #641
    Member Khalid's Avatar
    Apr 2006
    Pakistan
    Default Re: DIY- CNC Embroidery Machine
    Kiefer, thanks for sharing the video. I hope you will come-up with good solution to your machine
    Please suggest improvement in the software ...
    Tivoidethuong, how you are going?
    http://free3dscans.blogspot.com/ http://my-woodcarving.blogspot.com/
    http://my-diysolarwind.blogspot.com/
  2. #642
    Mar 2005
    ASIAN
    Quote Originally Posted by Khalid View Post
    I'm making hoopp for my embroidery machines
    almost finish
  3. #643
    Apr 2006
    Pakistan
    Hi Tivoidethuong,
    Thats a sturdy and very heavy duty setup.
    I just ordered :
    Arduino Mega 2560 R3 (Qty:01EA)
    RAMPS 1.4 Controller (Qty:01Ea)
    A4988 Stepper Driver Module (Qty:04EA) (I will use NEMA17 stepper motors and only need two of them)
    Full Graphic Smart LCD12864 controller (Qty:01Ea)
    Here is the link:
    1pcs Mega 2560 R3 + 1pcs RAMPS 1.4 Controller + 5pcs A4988 Stepper Driver Module +1pcs 12864 controller for 3D Printer kit-in 3D Printer Parts & Accessories from Computer & Office on Aliexpress.com | Alibaba Group
  4. #644
    Apr 2006
    Pakistan
    I have also designed a low-cost DC motor controller using one DPDT relay and two MOSFETs. The driver will do PWM and direction control of DC motor.
    DIY- CNC Embroidery Machine-dc-motor-controller-png
  5. #645
    Registered kiefer's Avatar
    May 2012
    us
    Hi Tivoidethuong,
    I just ordered :
    Here is the link:
    I agree absolutely with you.
  6. #646
    May 2012
    us
    Hi Khalid,
    just to let you know, the Gcode generator works very well. I triad it with my machine, and it works beautiful.Hopefully, I'll be able to make a new video soon.
  7. #647
    Apr 2006
    Pakistan
    Quote Originally Posted by kiefer View Post
    Hi Khalid,
    Kiefer,
    Good to know a good news from you .... Now i can't wait to see the video. Can you make a multicolor (atleast two color) design.. I want to check wether machine stop for changing thread or not?... Also want to see the beauty of multi-color design...
    Is it correct to say that the addition of Zparameters in Jump stitch is doing good job compare to no Zparameters..? can u share the picture of the design u did on ur machine?
  8. #648
    May 2012
    us
    Yes machine stops, and I don't see any bad part in the generator. My servo decided to stop to work - so I'm fighting to find out what is going on.
  9. #649
    May 2012
    us
    The way how to code finishes is nice too. Everything goes to zero, and everything is ready for a next design. Bravo
  10. #650
    Apr 2006
    Pakistan
    Oman...show us the pictures
  11. #651
    Apr 2006
    Pakistan
    Kiefer,
    I want to see two pictures:
    1- The completed design in the Hoop
    2- The screenshot of the design in software with hoop
    I just want to compare how accurately the hoop is generated in the software
  12. #652
    May 2012
    us
    Kiefer,
    It looks like my servo is broken.DIY- CNC Embroidery Machine-screenshot-3-png
  13. #653
    Apr 2006
    Pakistan
    Kiefer,
    Didn't you post the picture of actual embroidery!!! Hope you will comeup with solution to the Servo
  14. #654
    May 2012
    us
    Kiefer,
    I don't have a picture of a complete work. Machine doesn't work. I'm looking to buy a new servo motor.
  15. #655
    Apr 2006
    Pakistan
    You can share the picture of partial work
  16. #656
    Apr 2006
    Pakistan
    Experimenting with home made closed loop servo system. The three IR sensors scavenged from laser printer. The one will be used for index, the second one for direction and third one for speed control. The DC motor is scavenged from drill machine purchased from Karachi.
    The control loop will be interrupt base and PID/PWM control using microcontroller.
    The parts are ready for 3D printing.
    Attached Thumbnails Attached Thumbnails DIY- CNC Embroidery Machine-render-jpg
  17. #657
    Mar 2005
    ASIAN
    cool, are you have 3d printer?
  18. #658
    Apr 2006
    Pakistan
    Yes i have my own-designed Home made 3D Delta printer. The parts are now printing in Black ABS plastic.
  19. #659
    Mar 2005
    ASIAN
    great, maybe I should have planned diy 1 the 3d printer
    what is source code for 3d printer you use?
  20. #660
    Apr 2006
    Pakistan
    Nice Picture and i hope you will soon show your first embroidery work.. I am using Marlin Firmware and Cura as slicer to generate Gcode for 3D model.
