Dear Kiefer,
Please see the attach code.. do you want like this:
G01 X-7.2 Y-79 Z39750
G01 Z39760
G01 X-7.2 Y-79 Z39770
G01 Z39780
(NEEDLE UP RAPID MOVE- Light bulb Off if On)
M09
G01 X-7.2 Y-79
G01 X-12 Y-67.3
(START STITCHING- Light Bulb Off if On)
M09
G01 X-16.7 Y-55.6 Z39790
G01 Z39800
(THREAD COLOR CHANGE- M7 Light Bulb On)
G01 X-21.5 Y-43.9
M07
M06
M09
G01 X-21.5 Y-43.9 Z39810
G01 Z39820
G01 X-21.5 Y-43.9 Z39830
G01 Z39840
G01 X-21.8 Y-42.9 Z39850
G01 Z39860
G01 X-22.4 Y-42 Z39870
G01 Z39880
G01 X-22.8 Y-41.3 Z39890
http://free3dscans.blogspot.com/ http://my-woodcarving.blogspot.com/
http://my-diysolarwind.blogspot.com/
Kiefer, Here is the update:
1- You can now change Z-value in initial settings the minimum is 1
2- Changes made in the Gcode generation algorithm as mentioned in above post
Please replace the file and let me know if you need any help.
OK
here is again something:
line 706 and 707
G01 Z6820\
Mach3 wouldn't read this. You must delete this character first.
I found this in this code here:
Line 706: G01 Z6820\
Line 707: \
Line 1868: G01 Z18260\
Line 1869: \
Line 2334: G01 X-4.5 Y22.2 Z22910\
Line 2335: \
Line 3039: G01 X2.2 Y0.9 Z29810\
Line 3040: \
pls post the DST file from which you are generating the Gcode.
It doesn't appear here on my computer. Kiefer pls send me the GCODE file to see.
The "Space" or a blank line is converted to "/" .. Please see the latest update and let me know
If you open the file with WordPad, there is only empty space.
If you try to load the G code to mach 3 - it recognizes as a bad character.
I open the file with Notepad++, and I can see it.
I checked many different files, and appears in every file
here is the g code
I have to go now to work
this is my file
Okay Tivoi, i shall check your file and let me see the problem.
Tivio, pls check this and tell me are u still finding the bad character?
{\rtf1\ansi\deff0\deftab720{\fonttbl{\f0\fswiss MS Sans Serif;}{\f1\froman\fcharset2 Symbol;}{\f2\fswiss Tahoma;}}
{\colortbl\red0\green0\blue0;\red255\green102\blue 51;\red204\green204\blue51;\red245\green200\blue50 ;}
\deflang1033\pard\plain\f2\fs17 (The Gcode created with Embroidery Code Generator V2.4.5)
\par (Program Author: Khalid Farooq Khattak)
\par (Registered To: Beta)
\par (File Name: Crown.DST)
\par (Height x Width of Design 52.7 x 73.4)
\par (Total No. of Stitches: 4567)
\par (Total No. of Colors: 3)
\par (Important Notes: Final Gcode)
\par G90
\par G21
\par G64
\par F 1500
\par (START STITCHING- Light Bulb Off if On)
\par M09
\par G01 X-0.1 Y0 Z10
\par G01 Z20
\par (NEEDLE UP RAPID MOVE- Light bulb Off if On)
\par M09
\par G01 X-0.1 Y0
\par M09
\par G01 X-0.4 Y-7.5 Z30
\par G01 Z40
\par G01 X-0.6 Y-15 Z50
\par G01 Z60
\par G01 X-0.6 Y-16.2 Z70
\par G01 Z80
still have bad character
Okay here is the new Version 2.4.6, i have made a major revision in file storage. Hope this will solve the problem.
to khalid, software work perfect
(The Gcode created with Embroidery Code Generator V2.4.6)
G90
G21
G64
F 1500
M09
G01 X-0.1 Y0 Z10
G01 Z20
M09
G01 X-0.1 Y0
M09
G01 X-0.4 Y-7.5 Z30
G01 Z40
G01 X-0.6 Y-15 Z50
G01 Z60
G01 Z80
G01 X0.9 Y-15.4 Z90
G01 Z100
to khalid, you need fix Feedrate , about 1000~10000 >> 100~ 1000 stick per min
give me the formula if you have?
