Originally Posted by
Rene Nuñez Paz
Hello Khalid
Downloaded and installed new update, works perfectly, thanks
I send you some questions.
1-Generated G CODE for Floral Bucket is this way...
G90
G21
G64
F 1500
(NEEDLE UP RAPID MOVE- Light bulb Off if On)
M09
G00 X0.1 Y0 Z-2
G00 X0.1 Y0 Z-2
G00 X0.1 Y0 Z-2
G00 X0.1 Y0 Z-2
I need to know what meanings in embroider this 4 similar lines,. If is this lines are necessary, then It should be a M786 Macro line after last G00 X0.1 Y0 Z-2 , to reset Z.
ANS: Actually only One line should be their. Later i will add M786 if the time permit...
2-I think than in your software, Z movements should be by default in this way
Z MOVES activated
Short Z = -2
Z moves = -8
If some one wants to modify and use another setting or value, is free to do it, but it seems, than set this values in default mode are logic and practical for majority of users.
ANS:
My machine works with following setting
Z MOVES activated
Short Z = -0.4
Z moves = -0.6
3-If is possible, when you make another update, is a good thing if you includes another option in G CODE Parameters. It will be a M7 and a M9 Lines, for needle job. using a AC-DC motors in combination with electric diagram similar like I posted 2 days ago, In this case, is possible set this option and not use Z or A settings.
ANS: Can be done later but it require time.. I temperorily suspended work on new revision of this software due to some problems...
By the way, I was looking in electronic equipment pages and found an electric controller for rapid start/stops of lights or another equipment, this don’t use a magnetic starter, its using a TRIACS, electronic components, It’s not the controller what we need but if useful for an idea, to we need for controlled start/stop of ac/dc motor in sewing machine, and don’t use a stepper in this case.
ANS: I just want to know about the outcome of your work.. Basically you can activate the motor through relay but how will you stop it.. Let us say M7 start the DC motor and when Mach3 M9 to stop the motor, the motor will run some degrees with its inertia..how to compensate it.. May be some breaking Mcode?
4-I was looking in Wilcom Spanish tutorial, and read than one must set at beginning and finish embroider work, a some kind of stitches combination, called like this “nudo de seguridad de las puntadas”, to get firm embroider work, In g code generated are this lines?
ANS: Yes Wilcom can be programmed to give you reinforcement stitches... The output DST file will contain this information and my software will do the reinforcement stitches as in DST.
5-I was reading about cross stitches embroider work, Actually Iam using SophieSew , and is not this kind of stitches. Do you Know if in Wilcom or another design embroider software are this stitches?
Ans:Wilcom support cross-stitches.
Thanks for your help and support.
Bye
Rene
