Maybe your post got cut off?
What travels do you want? Why do you need those travels?
What materials will you be cutting?
You need diagonal bracing.
It is easy to make a fixed gantry more rigid - go bigger and add diagonal bracing to the uprights.
What is the size of your gantry beam?
