Need Help! CNC Router for routing Carbon fibre
Results 1 to 3 of 3
Thread: CNC Router for routing Carbon fibre
    Member Soundharya's Avatar
    Jun 2019
    Default CNC Router for routing Carbon fibre
    Hello!
    I'm currently in the process of designing a CNC Router for routing carbon fibre. I need help in selecting a spindle for the same.
    I have thought of going with Bosch GKF125CEN Palm Router - 1.25 HP. I wanted to check if anyone has used this spindle for machining carbon fibre and also is the torque and power of this spindle sufficient to machine carbon fibre?
    Would love to get a reply for this ASAP!
    Thank you for your time in advance!
    Regards
    Soundharya
    Feb 2005
    Default Re: CNC Router for routing Carbon fibre
    AFAIK that is the bosch colt router. they are hit or miss on bearing quality, this can cause excessive spindle play.
    - - - Updated - - -
    I know alot of people have had good luck with this one
    https://www.amazon.com/DEWALT-DWP611-Torque-Variable-Compact/dp/B0048EFUV8/ref=pd_lpo_sbs_469_t_0?_encoding=UTF8&psc=1&refRID=2BS4JCT3VEWTHZ13D1XH
    Member routalot's Avatar
    Dec 2003
    Do make an effort to provide very good extraction when machining carbon.If it gets into the important parts of the machine there will be cackling and sparking and maybe much worse.It is even more important if the carbon has been autoclave cured as the fibre fraction is higher.
