New Machine Build My second build,, all in steel from Cuba
Results 1 to 11 of 11
Thread: My second build,, all in steel from Cuba
    Feb 2007
    CUBA
    Default My second build,, all in steel from Cuba
    Hi everyone!!
    Here you have a picture of my second build, all in steel
    cutting size 4' x 4' x 4 inches.
    Main use will be plastics and wood.
    My first buld was a JGRO 11 years ago. Its still working after some
    repair work.(end of the picture)
    Summary of the parts.
    Table legs in 3 inches Steel angle, all weld
    Table estructure in 1" x 2" x 2mm
    X and Y Axis support in 2" x 2" square tube filled with hard wood in all places where
    are bolts.
    Rails in 3/4" steel angle
    V Wheels and bushings cuban made,2 6000type bearingsin each vwheel.
    1/2" 10 ACME 5Starts for X and Y axis from Mc Master
    1/2" 8 ACME 2 sTART for Z Axis from Mc Master
    Standard Anti-backlash Kit from Dumpster CNC
    1/2" Pressed Steel Two Bolt Flange Bearing
    CNC Controler, power source and steppers from AutomationTechnologies
    4 axis, KL4030 STEPPER DRIVERS
    4 KL23 STEPPER MOTORS
    I know that here are some problems about inductancy, later I will
    ask about help for this part.
    Now Iam working in squaring the axis and leveling.
    Next step electricity
    Please give a look
    Opinions are well received.
    The most important part were imported from USA.
    I want to thanks for every one in this forum
    that share his desings and knowledge for free.
    Sorry my bad english, is not my native idiom.
    Thanks in advance
    Rene
    My second build,, all in steel from Cuba-img_3917-jpgMy second build,, all in steel from Cuba-img_3917-jpgMy second build,, all in steel from Cuba-2-jpg
    Sep 2005
    Default Re: My second build,, all in steel from Cuba
    Very nice looking.
    1000x750 Workbee CNC - Mach4 - PMDX USB - Windows 10 Pro
    Feb 2007
    CUBA
    Thanks, its a work in proccess,, still a lot to learn...
    Feb 2007
    CUBA
    MORE PICS OF BUILD
    My second build,, all in steel from Cuba-antibackslash-mount-jpgMy second build,, all in steel from Cuba-base-jpgMy second build,, all in steel from Cuba-flange-bearings-jpgMy second build,, all in steel from Cuba-guide-calibration-jpgMy second build,, all in steel from Cuba-modular-axis-jpgMy second build,, all in steel from Cuba-rails-aligment-jpgMy second build,, all in steel from Cuba-stepper-mount-jpgMy second build,, all in steel from Cuba-tube-reinforcement-hard-wood-jpg
    Nice looking machine!
    Mar 2019
    Lightbulb Re: My second build,, all in steel from Cuba
    Great Job !!!
    More pictures, please
    Por favor, más detalle del pórtico ¿podría poner planos o información más detallada? Ha hecho un trabajo genial y me gustaría mucho seguirlo para fabricarme una similar.
    Los cubanos sois geniales.
  7. #7
    Feb 2007
    CUBA
    Hola Alejandro. Hacia dias que no pasaba por aqui.
    En realidad no tengo muchos planos, solo algunos esquemas.
    Hoy instale el portico. Mañana le hago algunas fotos y las subo.
  8. #8
    Member peteeng's Avatar
    Jul 2018
    dum dum
    your on your way to a very good machine - Peter
  9. #9
    Feb 2007
    CUBA
    Hello
    Today my router begin to move
    Steppers are working fine and movement is smooth.
    Set Drivers 1/8 microstep
    Drivers 2.7 A
    Full Current
    Speed for test 60 IPM.
    I have this problem.
    C10 BREAKOUT BOARD LED remains ON
    when I turn OFF controller, If I deconnect
    the paralell cable then Led comes OFF.
    c37 Single Relay Board has the Power LED and the
    Activation LED.
    When controller and PC are Off then
    Power led too is ON and
    Activation LED is OFF
    WHEN Controller is ON, then this leds gets brighter.
    When I start PC , during the procces of WINDOws
    charge, the Activation LED gets ON and I have 110volts
    in Spindle. and when I open MACH 3, Activation LED
    gets OFF.
    How can I fix this?
    Thanks in advance for your help
    My second build,, all in steel from Cuba-img_4361-jpgMy second build,, all in steel from Cuba-leds-problem-jpgMy second build,, all in steel from Cuba-controller-jpg
  10. #10
    Feb 2007
    CUBA
  11. #11
    Feb 2007
    CUBA
    Fixed the problem
    It was a bad connection of GND of C37 Relay. I was taking from negative wire of 5 volts PS. Now is connected to GND in C10 Breakout board.
    Spindle star and stops perfectly.
    Dry run of the machine X Axis 150 IPM work fine
    Tomorrow I will test Y axis.
