Aluminum frame cnc
Results 1 to 2 of 2
Thread: Aluminum frame cnc
    Jul 2009
    Default Aluminum frame cnc
    Finally posting my new cnc build. Using all aluminum frame components. 20mm profile rails. 16mm ballscrews. Closed loop steppers. Will post more pics later. Progress thus far...
    Sent from my LM-Q710(FGN) using Tapatalk
    Member CitizenOfDreams's Avatar
    Nov 2012
    Default Re: Aluminum frame cnc
    Looks interesting so far. Keep the pictures coming, I will go grab some popcorn.
    So this is a moving table setup? I presume the profile rails will be raised to make room for the ball screw?
Aluminum frame cnc
Aluminum frame cnc
Aluminum frame cnc
