can i fix this directly from the cnc softwars (GRBL / LINUXCNC / MACH3 )?
Results 1 to 2 of 2
Thread: can i fix this directly from the cnc softwars (GRBL / LINUXCNC / MACH3 )?
    Registered abdelkrim30's Avatar
    Nov 2018
    Exclamation can i fix this directly from the cnc softwars (GRBL / LINUXCNC / MACH3 )?
    Hello, friends, I have some questions. I hope you will help me in answering them.
    Yesterday I finished making my CNC machine table but there are some mistakes in the measurements because the iron bar I used was not 100% straight.
    This simple diagram shows the place of simple curvature in iron bar.
    https://files.fm/u/knuw8wwx#/view/cnc.jpg
    My question is whether i can fix this directly from the cnc softwars (GRBL / LINUXCNC / MACH3 ) or i should make a new table . and thank you for help
    Attached Thumbnails Attached Thumbnails can i fix this directly from the cnc softwars (GRBL / LINUXCNC / MACH3 )?-cnc-jpg
    Mar 2008
    Default Re: can i fix this directly from the cnc softwars (GRBL / LINUXCNC / MACH3 )?
    1cm seems like a lot. Cut the bar and re weld it to a closer tolerance. Then use a spoil board that you can machine flat. That's about how every CNC is made.
