New Machine Build Yet another 3 axis CNC Router Design/Build - Page 2
Page 2 of 2 FirstFirst 12
Results 13 to 23 of 23
Thread: Yet another 3 axis CNC Router Design/Build
  1. #13
    Mar 2018
    Default Re: Yet another 3 axis CNC Router Design/Build
    PS: This one is by far one of the coolest minimalistic looking gantrys available.
    On the same channel is another video of it with a hexapod. Alien...
  2. #14
    Feb 2015
    Quote Originally Posted by ger21 View Post
    The rigidity of the total assembly will have more to do with it than the bearing spacing. If the entire bolted assembly is capable of flexing at all, then you'll likely see some racking.
    While deflection may not be an issue, you might see vibration during cutting, which may have an effect on cut quality.
    Ok, I am thinking that I will start with a single centered ball screw drive for the gantry, but will make provisions to easily add a second ball screw (one on LH side and one on RH side) if the bolted assembly proves to not be rigid enough.
    Good point on vibration and chatter, yet another oversight. I think that I am going to start with what I have, I can add additional stiffening members under the table, as I do have extra room.
  3. #15
    Feb 2015
    millhouse,
    I understand the advantages of the designs that you are suggesting, but I am thinking that the tall gantry plate design will suffice for my needs. Perhaps there will be a second build in my future with this type of design.
    The last video that you posted is one sweet looking machine. Thanks for sharing.
  4. #16
    Feb 2015
    Update;
    Reduced gantry side plate height by 2.25".
    Designed z axis assembly with supported profile rails (6.5" of travel).
    What are people's thoughts on a counterbalance for the z axis?
    Yet another 3 axis CNC Router Design/Build-2018-10-26_1-jpg
    Yet another 3 axis CNC Router Design/Build-2018-10-26_2-jpg
    Attached Thumbnails Attached Thumbnails Yet another 3 axis CNC Router Design/Build-2018-10-26_1-jpg   Yet another 3 axis CNC Router Design/Build-2018-10-26_2-jpg
  5. #17
    Mar 2018
    Maybe you should switch to 25mm linear rails for the long axis. With the rails mounted at the sides the whole weight of the gantry pushes against only 1 row of the bearingballs so using bigger ones would be better.
    Your builds size is similar to my one (see attachment framesize 1000mm x 800m) and I used 25mm rails on all axis:
    I don't think that you "need" a counterweight but if you want to implement one you could use gas springs like the ones in the video of the minimalistic gantry or just a spring, mounted from the z backplate to the frontplate.
    Attached Thumbnails Attached Thumbnails Yet another 3 axis CNC Router Design/Build-bildschirmfoto-vom-2018-10-26-21-44-a
  6. #18
    Mar 2003
    20mm rails can handle several thousand pound loads. You won't be using 10% of their capacity.
    Yeah, no need for a counterweight on a little Z axis like that.
    UCCNC 2017 Screenset
    http://www.thecncwoodworker.com/2017.html
    http://www.thecncwoodworker.com/2010.html
    http://www.g-forcecnc.com/jointcam.html
  7. #19
    Feb 2015
    Looking at the specs, I thought that 20mm rails would be adequate.
    Thats x2 on not having a counterbalance for the z... good deal, one less component to design around.
    thanks folks!
  8. #20
    Jan 2008
    I don't understand the benefit of using aluminum extrusion with steel bolted on the outside.
    Just use steel.
    7xCNC.com - CNC info for the minilathe (7x10, 7x12, 7x14, 7x16)
  9. #21
    Feb 2015
    To cut down on the number of machined components, the thought is to use a table structure that is known to have a relatively good straightness tolerance ie extruded Al, and skin it with a material that is known to have a uniform thickness tolerance to create a planer surface for the rails to fasten to. A steel structure would require machining for flatness or an epoxy pour. I do not have economical access to machine long parts.
    Perhaps this isn’t the best approach, but it seams to be the best given the processes readily available to me.
    That being said, I would prefer to build the table out of steel...
  10. #22
    Feb 2015
    Project update.
    Welded base
    Yet another 3 axis CNC Router Design/Build-welded-base-jpg
    Laser cut sheet metal
    Yet another 3 axis CNC Router Design/Build-laser-cut-sheet-metal-jpg
    80/20 machined
    Yet another 3 axis CNC Router Design/Build-machined-8020-jpg
    table assembly
    Yet another 3 axis CNC Router Design/Build-8020-assembly-jpg
    Yet another 3 axis CNC Router Design/Build-table-assembled-jpg
    Attached Thumbnails Attached Thumbnails Yet another 3 axis CNC Router Design/Build-table-assembled-jpg   Yet another 3 axis CNC Router Design/Build-welded-base-jpg   Yet another 3 axis CNC Router Design/Build-laser-cut-sheet-metal-jpg   Yet another 3 axis CNC Router Design/Build-machined-8020-jpg
    Yet another 3 axis CNC Router Design/Build-8020-assembly-jpg   Yet another 3 axis CNC Router Design/Build-8020-assembly-2-jpg
  11. #23
    Feb 2015
    FYI, by no means do I consider myself to be a welder.
