Another Aussie Auto Tool Zero Setter - Page 29
Page 29 of 29 FirstFirst ... 1926272829
Results 561 to 564 of 564
Thread: Another Aussie Auto Tool Zero Setter
  1. #561
    Registered jadmaz's Avatar
    Sep 2016
    Lebanon
    Default Re: Another Aussie Auto Tool Zero Setter
    Thanks for the all of you for this Useful information
    Sent from my SM-J700H using Tapatalk
  2. #562
    Sep 2016
    Lebanon
    I built a new cnc machine and I have a problem in zeroing so i will try again now
  3. #563
    Sep 2016
    Lebanon
  4. #564
    Aug 2008
    Default Another Aussie Tool setter not working with SmoothStepper
    hi Guys
    have run my machine with Greolt's Aussie tool Setter for a number of years and everything worked well.
    had to change computers recently and now running Windows 10 with ESS SmoothStepper. All if fine apart from the Tool Setter now not working.
    I have tried using Greolt's 'Modified 1024 screenset and the probe/Touch plate registers on the LEd and in the Diagnostics page. I have set the thickness of the touch plate, however, it always seems to hang at the "G4 P3" - "G90 G31Z-4. F4" section.
    Any ideas - it is driving me nuts.
    Using CNC4PC C10 Bob's - work well - and the inputs set to 'Pull High' and the Pins sets to 'Active Low'. The input pins are at 4.98v.
    Any and all suggestions greatly appreciated.
    Cheers
    Noel
