@Zekyx
I tried to control it with Pokeys via 0-10V analog signal. I could start the spindle with software but there was a problem with rpm, Spindle only worked at a fixed rpm regardless of the software commands.
Now I am controlling the spindle manually, I will try to control it with software again later. If I figure it out I will let you know.
