Next tasks were fitting the Y axis ballscrew and making/fitting the Z motor mount. The ballscrew support bearings were mounted on the aluminium gantry uprights, a jig was made to lay a bed of epoxy on the aluminium for the bearings at equal distance from the Y rails (remember that the extusion does not have flat faces). The ball screw was fitted with a measured runout of 0.02-0.03mm. This was higher than I hoped to achieve but the screw had a small bend in it which made measurement tricky. In use the screw is very smooth with no binding or stiffening. I will check that the nut does not get warm in use, indicating an alignment problem. I then manually machined a yoke to connect the ball nut to the Z plate. You can see the epoxy bed for the bearings in the pic.
