WidgitMaster's Largest Steel Router Table Project 9ft x 5ft x 8" Water Cooled Spindle - Page 89
Page 89 of 91 FirstFirst ... 3979868788899091 LastLast
Results 1,761 to 1,780 of 1805
Thread: WidgitMaster's Largest Steel Router Table Project 9ft x 5ft x 8" Water Cooled Spindle
  1. #1761
    Member Bubba's Avatar
    Mar 2004
    lagrange
    Default Re: WidgitMaster's Largest Steel Router Table Project 9ft x 5ft x 8" Water Cooled Spi
    Excellent as it sounds like your making positive progress on all fronts. Hang in there my friend as you are always in our prayers and keep up the great works that you do.
    Art
  2. #1762
    The Vietnam traveling wall will be in town soon, so I've been working on a nice set for my friends booth!
    The USMC & USN are done, the USCG & USAF are on the pain bench!
    The ARMY had a crack in it, so I've had to cut another one!
    Attached Thumbnails Attached Thumbnails WidgitMaster's Largest Steel Router Table Project 9ft x 5ft x 8" Water Cooled Spindle-img_3440-jpg   WidgitMaster's Largest Steel Router Table Project 9ft x 5ft x 8" Water Cooled Spindle-img_3444-jpg   WidgitMaster's Largest Steel Router Table Project 9ft x 5ft x 8" Water Cooled Spindle-img_3446-jpg   WidgitMaster's Largest Steel Router Table Project 9ft x 5ft x 8" Water Cooled Spindle-img_3447-jpg
    WidgitMaster's Largest Steel Router Table Project 9ft x 5ft x 8" Water Cooled Spindle-img_3448-jpg   WidgitMaster's Largest Steel Router Table Project 9ft x 5ft x 8" Water Cooled Spindle-img_3458-jpg   WidgitMaster's Largest Steel Router Table Project 9ft x 5ft x 8" Water Cooled Spindle-img_3459-jpg
  3. #1763
    Finished painting another one!
    Attached Thumbnails Attached Thumbnails WidgitMaster's Largest Steel Router Table Project 9ft x 5ft x 8" Water Cooled Spindle-img_3460-jpg   WidgitMaster's Largest Steel Router Table Project 9ft x 5ft x 8" Water Cooled Spindle-img_3461-jpg
  4. #1764
    All done!
    It took me a while to finish them, but its was worth the effort!
    Hope you all like them!
    Widgit
    And yes, the New Space Force is next, but the Seal & Logos have not been officially released
    Attached Thumbnails Attached Thumbnails WidgitMaster's Largest Steel Router Table Project 9ft x 5ft x 8" Water Cooled Spindle-img_3463-jpg   WidgitMaster's Largest Steel Router Table Project 9ft x 5ft x 8" Water Cooled Spindle-img_3465-jpg   WidgitMaster's Largest Steel Router Table Project 9ft x 5ft x 8" Water Cooled Spindle-img_3470-jpg
  5. #1765
    Member peteeng's Avatar
    Jul 2018
    dum dum
    Hi Widget - What paint do you use thats so bright? Peter
  6. #1766
    Hello Peter!
    Actually, all I use is standard Matte finish Acrylic paints!
    All so, none of the last 5 plaques were clear coated yet!
  7. #1767
    Jul 2018
    dum dum
    Hi WM - Are they art type acrylic or housepaint? Peter
  8. #1768
    Quote Originally Posted by peteeng View Post
    All Artist paints! I prefer the matte paints, as it's easier to add additional coats for better colors on the absorbent wood!
    www.widgitmaster.com
    It's not what you take away, it's what you are left with that counts!
  9. #1769
    I realize it's been an incredibly long time since I've uploaded anything from the machine shop, so here is a project I've been working on for several months now!
    As Big-Red is now running better, I've noticed the water cooled spindle is running too hot! After investigating the cooling system, I realized the water lines were circulating hot water as the machine ran for hours!
    My solution is to add a little radiator with a 150-CFM fan! In order to do this I'll need to add an air filter, to keep the fine dust from clogging the radiator's fins !
    I had a mounting bracket made out of welded aluminum, which will support both the radiator and the fan! But attaching the air filter required a little more detailing!
    Attached Thumbnails Attached Thumbnails WidgitMaster's Largest Steel Router Table Project 9ft x 5ft x 8" Water Cooled Spindle-img_3488-jpg   WidgitMaster's Largest Steel Router Table Project 9ft x 5ft x 8" Water Cooled Spindle-img_3489-jpg   WidgitMaster's Largest Steel Router Table Project 9ft x 5ft x 8" Water Cooled Spindle-img_3490-jpg   WidgitMaster's Largest Steel Router Table Project 9ft x 5ft x 8" Water Cooled Spindle-img_3491-jpg
  10. #1770
    After mounting a 1" thick aluminum plate in the lathe chuck, I made a face cut and drilled a 2" dia. through hole. Next I expanded the bore to match the filter's bore!
    The I used a 45 deg. bit to make a nesting area that matches the angled protrusion on the ends of the filter! Then I turned the OD to match the filter's OD.
    Next, I needed to remove the Turret from the lathe, and put the single tool holder back on!
    This enabled me to flip the part, face the opposite side, and put a deeper 45 deg angle into the bore. this will improve the airflow from the fan's larger diameter to the filter's smaller diameter!
    Attached Thumbnails Attached Thumbnails WidgitMaster's Largest Steel Router Table Project 9ft x 5ft x 8" Water Cooled Spindle-img_3473-jpg   WidgitMaster's Largest Steel Router Table Project 9ft x 5ft x 8" Water Cooled Spindle-img_3474-jpg   WidgitMaster's Largest Steel Router Table Project 9ft x 5ft x 8" Water Cooled Spindle-img_3475-jpg   WidgitMaster's Largest Steel Router Table Project 9ft x 5ft x 8" Water Cooled Spindle-img_3476-jpg
    WidgitMaster's Largest Steel Router Table Project 9ft x 5ft x 8" Water Cooled Spindle-img_3481-jpg
  11. #1771
    Now it's time to switch chucks, so I can hold the part in soft-jaws. Then I placed a spider under the three jaws, and bored out a nest for the part to clamp into!
    Because the next cut requires a long radius cutter, I free-hand made one on the pedestal grinder using a 1/2 x 1/2 HSS tool bit!
    With the tool clamped in position, I carefully made a series of cuts in the edge of the part. This created two flanges, one fits up against the filter. The other will be machined square, to match the fan housing, and have holes for the attaching screws!
    It's been a long time for me, and standing in the shop is still a bit painful! But I did manage to get the rotary table setup on the mill, and made a fixture plate to securely attach the part in the center of the table! This will allow me to mill the fan side flange square, and drill the mounting holes!
    But not today!
    Attached Thumbnails Attached Thumbnails WidgitMaster's Largest Steel Router Table Project 9ft x 5ft x 8" Water Cooled Spindle-img_3482-jpg   WidgitMaster's Largest Steel Router Table Project 9ft x 5ft x 8" Water Cooled Spindle-img_3483-jpg   WidgitMaster's Largest Steel Router Table Project 9ft x 5ft x 8" Water Cooled Spindle-img_3484-jpg   WidgitMaster's Largest Steel Router Table Project 9ft x 5ft x 8" Water Cooled Spindle-img_3485-jpg
    WidgitMaster's Largest Steel Router Table Project 9ft x 5ft x 8" Water Cooled Spindle-img_3486-jpg
  12. #1772
    Member stragenmitsuko's Avatar
    May 2007
    na
    Nice to see shop pictures once more .
    A tip I got from a retired painter :
    To stop wood from absorbing the paint and needing multiple coats , apply one thin coat of latex or emulsion paint first
    This will seal the surface and fill minor imperfections .
    Then paint as you normally would , spray or brush .
    Pat .
  13. #1773
    More progress!
    Today I milled the fan side flange square, and drilled the four mounting holes.
    Then I put the vise back on the mill, so I could drill & ream a 1/2" diam. hole across the center, 45 deg. from the four mounting holes.
    This allowed me to place an aluminum pin across the bore. After a quick trip to the welder, I had the ends of the pin welded in place.
    As soon as it returned to my shop, I placed the part back in the lathe and re-surfaced the edge radius.
    Attached Thumbnails Attached Thumbnails WidgitMaster's Largest Steel Router Table Project 9ft x 5ft x 8" Water Cooled Spindle-img_3492-jpg   WidgitMaster's Largest Steel Router Table Project 9ft x 5ft x 8" Water Cooled Spindle-img_3494-jpg   WidgitMaster's Largest Steel Router Table Project 9ft x 5ft x 8" Water Cooled Spindle-img_3495-jpg   WidgitMaster's Largest Steel Router Table Project 9ft x 5ft x 8" Water Cooled Spindle-img_3496-jpg
    WidgitMaster's Largest Steel Router Table Project 9ft x 5ft x 8" Water Cooled Spindle-img_3497-jpg   WidgitMaster's Largest Steel Router Table Project 9ft x 5ft x 8" Water Cooled Spindle-img_3498-jpg   WidgitMaster's Largest Steel Router Table Project 9ft x 5ft x 8" Water Cooled Spindle-img_3505-jpg   WidgitMaster's Largest Steel Router Table Project 9ft x 5ft x 8" Water Cooled Spindle-img_3506-jpg
  14. #1774
    The pin that crosses the bore will allow me to attach a long pin down the center of the filter, which will allow an end cover plate for the filter.
    That's a job for tomorrow!
    Attached Thumbnails Attached Thumbnails WidgitMaster's Largest Steel Router Table Project 9ft x 5ft x 8" Water Cooled Spindle-img_3500-jpg   WidgitMaster's Largest Steel Router Table Project 9ft x 5ft x 8" Water Cooled Spindle-img_3501-jpg
  15. #1775
    Today I drilled & tapped a hole in the cross-bar, then I made a small spot-face the same diameter as the long shaft.
    Then I drilled & tapped the end of the long shaft, put a screw tightly into the bottom of the threaded hole, then cut the head off the screw.
    Next I screwed the parts together, and used the Height Gage transfer a mark onto the long shaft. Then I cut off the excess, drilled & tapped the end.
    With all that done, I drilled a small hole in a piece of aluminum plate, bandsawed the corners off and turned the OD on the lathe
    With a little radius tool, I made the top cover plate look nice!
    Attached Thumbnails Attached Thumbnails WidgitMaster's Largest Steel Router Table Project 9ft x 5ft x 8" Water Cooled Spindle-img_3507-jpg   WidgitMaster's Largest Steel Router Table Project 9ft x 5ft x 8" Water Cooled Spindle-img_3508-jpg   WidgitMaster's Largest Steel Router Table Project 9ft x 5ft x 8" Water Cooled Spindle-img_3509-jpg   WidgitMaster's Largest Steel Router Table Project 9ft x 5ft x 8" Water Cooled Spindle-img_3510-jpg
    WidgitMaster's Largest Steel Router Table Project 9ft x 5ft x 8" Water Cooled Spindle-img_3511-jpg   WidgitMaster's Largest Steel Router Table Project 9ft x 5ft x 8" Water Cooled Spindle-img_3512-jpg   WidgitMaster's Largest Steel Router Table Project 9ft x 5ft x 8" Water Cooled Spindle-img_3513-jpg   WidgitMaster's Largest Steel Router Table Project 9ft x 5ft x 8" Water Cooled Spindle-img_3514-jpg
  16. #1776
    Now It's off to assembly!
    Tomorrow I decide where on Big-Red it will be mounted!
    Attached Thumbnails Attached Thumbnails WidgitMaster's Largest Steel Router Table Project 9ft x 5ft x 8" Water Cooled Spindle-img_3520-jpg   WidgitMaster's Largest Steel Router Table Project 9ft x 5ft x 8" Water Cooled Spindle-img_3519-jpg
  17. #1777
    Got them all finished!
    Attached Thumbnails Attached Thumbnails WidgitMaster's Largest Steel Router Table Project 9ft x 5ft x 8" Water Cooled Spindle-584736fb-c115-4d46-91a5-4f649259453a-jpg   WidgitMaster's Largest Steel Router Table Project 9ft x 5ft x 8" Water Cooled Spindle-0d308875-0a52-414b-ae54-acc914986019-jpg
  18. #1778
    Jul 2018
    dum dum
    Hi WidgitM - excellent metal and wood work. Keep it up. Peter
  19. #1779
    Mar 2004
    lagrange
    Widgit,
    You continue to amaze me with the work and service that you continue to do. Keep it up and stay safe.
    Art
  20. #1780
    Thanks guys!
    You-all stay healthy !
    Widgit
