WidgitMaster's Largest Steel Router Table Project 9ft x 5ft x 8" Water Cooled Spindle - Page 143
Page 143 of 145 FirstFirst ... 4393133140141142143144145 LastLast
Results 1,705 to 1,716 of 1729
Thread: WidgitMaster's Largest Steel Router Table Project 9ft x 5ft x 8" Water Cooled Spindle
  1. #1705
    Apr 2007
    Default Re: WidgitMaster's Largest Steel Router Table Project 9ft x 5ft x 8" Water Cooled Spi
    It's great to see you back in this thread Widgitmaster!!
    I got worried about you over the summer months and finally and asked Gerry if he could help get this fixed. I tried to contact you via PM and found that it was full. I hope all is as well as it can be since your accident. I hang out in the The Vectric Ltd User Forums mostly, but come back here to browse once in a while. That's where all of my own completed projects are shown.
    CarveOne
    CarveOne
    http://www.carveonecncwoodcraft.com
  2. #1706
    Jan 2005
    Quote Originally Posted by widgitmaster View Post
    Bought it from McMaster-Carr https://www.mcmaster.com/9936K65
    Length, ft.
    10
    20
    30
    50
    100
    Other
    Each
    Delivers Friday
    1-99 Ft. $5.55
    100 or more $4.67
    9936K65
    1 each ordered on January 29, 2017 0128EARNOLD.
    Shielding Shielded
    Shield Type Braid
    Wire
    Type Stranded
    Material Bare Copper
    Flexibility Flexible
    Wire Gauge 16
    Number of Wires 3
    Cable AWG 16/3
    OD 0.38"
    Current 18 A @ 86° F
    Voltage 600V AC
    Temperature Range 45° to 190° F
    Wire Marking Numbered
    Specifications Met UL Recognized; UL Flame Rated VW-1; CSA Certified
    Use For Automation, Interference Shielding
    Inner Insulation Material PVC
    Inner Insulation Color Black, Green/Yellow
    Outer Insulation Material PVC
    Outer Insulation Color Gray
    RoHS Compliant
    The braid shielding in this cable prevents electromagnetic interference (EMI) to minimize signal distortion. Control conveyors, CNC machines,and other types of automated equipment that requires cable to periodically bend and flex. The insulation resists oil.
    Length, ft.
    10
    20
    30
    50
    100
    Other
    Each
    Delivers Friday
    1-99 Ft. $5.55
    100 or more $4.67
    9936K65
    Shielding Shielded
    Shield Type Braid
    Wire
    Type Stranded
    Wire Gauge 16
    Number of Wires 3
    Cable AWG 16/3
    OD 0.38"
    Voltage 600V AC
    RoHS Compliant
    Not sure where you would of used this cable as it is only 3 wire you need a 4 wire cable for your spindle, and this is also expensive cable compared to the cable I recommend for VFD Drive to Spindle IGUS CF6-15-04 at $2-34 /Ft from Automation Direct and from IGUS $2-65 / Ft
    Mactec54
  3. #1707
    Member Sunnychen's Avatar
    Oct 2019
    Nice
  4. #1708
    Member widgitmaster's Avatar
    Jun 2005
    I've been working on a big project, now that it's finished, I can upload some images!
    1st I ripped some yellow pine 2" x 12"in to 2" wide strips. Then I used a biscuit cutter to put 4x evenly spaced biscuits about 1/4" from the bottom. Glued & Clamped everything together.
    The resulting panel was 48" x 25" x 1 1/2"
    Next I drilled & countersunk for a flat head wood screw in the corners, this allowed me to shim the panel so it sat flat on the table! Then I took a light cut on the bottom surface to make it all flat.
    Then I flipped it over, countersunk the holes again, and established my X & Y zeros.
    The entire carve took 3 hours!
    Then I spent 32 hours hand painting it!
    Needless to say, the American Legion post was pleased!
    I'm a member of the Legion Riders, and this is one of many posts we visit in the state!
    PS: It's nice to be able to post on this thread again
    Attached Thumbnails Attached Thumbnails WidgitMaster's Largest Steel Router Table Project 9ft x 5ft x 8" Water Cooled Spindle-img_3174-jpg   WidgitMaster's Largest Steel Router Table Project 9ft x 5ft x 8" Water Cooled Spindle-img_3196-jpg   WidgitMaster's Largest Steel Router Table Project 9ft x 5ft x 8" Water Cooled Spindle-img_3197-jpg   WidgitMaster's Largest Steel Router Table Project 9ft x 5ft x 8" Water Cooled Spindle-img_3197b-jpg
    WidgitMaster's Largest Steel Router Table Project 9ft x 5ft x 8" Water Cooled Spindle-img_3209-jpg   WidgitMaster's Largest Steel Router Table Project 9ft x 5ft x 8" Water Cooled Spindle-img_3210-jpg   WidgitMaster's Largest Steel Router Table Project 9ft x 5ft x 8" Water Cooled Spindle-img_3211-jpg   WidgitMaster's Largest Steel Router Table Project 9ft x 5ft x 8" Water Cooled Spindle-img_3213-jpg
    www.widgitmaster.com
    It's not what you take away, it's what you are left with that counts!
  5. #1709
    Member Bubba's Avatar
    Mar 2004
    LaGrange, GA USA
    Welcome back and happy to see your works again. It may have taken a great deal of time to make, but the results are well worth it.
    Beautiful piece.
    Art
    Country Bubba (Older Than Dirt)
  6. #1710
    Apr 2007
    Excellent job sir, and a nice tribute to them.
    I have been considering doing something new for American Legion Post 38 soon. As a member I have made a meeting room sign dedicating a new name for the room in honor of the founding member of that Post, and built a US Flag Drop Box for them with welded sheet steel. Both were designed in Aspire software, but the 3/32" sheet steel was cut by hand. These CNC machines have plenty of good uses for charitable purposes.
    CarveOne
    CarveOne
  7. #1711
    Jun 2005
    Its good to be back on the Zone!
    I've made another American Legion plaque, it took two hours to carve and 3-days to paint !
    Never realized how relaxing it is to paint, it's very therapeutic for my P.T.S.D. !
    The 3x power magnifier helps a lot too!
    Attached Thumbnails Attached Thumbnails WidgitMaster's Largest Steel Router Table Project 9ft x 5ft x 8" Water Cooled Spindle-img_3227-jpg   WidgitMaster's Largest Steel Router Table Project 9ft x 5ft x 8" Water Cooled Spindle-img_3230-jpg   WidgitMaster's Largest Steel Router Table Project 9ft x 5ft x 8" Water Cooled Spindle-img_3231-jpg   WidgitMaster's Largest Steel Router Table Project 9ft x 5ft x 8" Water Cooled Spindle-img_3232-jpg
    WidgitMaster's Largest Steel Router Table Project 9ft x 5ft x 8" Water Cooled Spindle-img_3237-jpg   WidgitMaster's Largest Steel Router Table Project 9ft x 5ft x 8" Water Cooled Spindle-img_3239-jpg
  8. #1712
    Mar 2004
    LaGrange, GA USA
    Impeccable as always. I enjoy seeing your workmanship and the results.
    Art
  9. #1713
    Jun 2005
    Default Can anyone tell me if Mach3 will run on Windows 10?
    Well, Big Red has died!
    Windows 7 cant be registered online, and its misbehaving so badly it cant run a long program!
    My research shows the cost of a DSP Pendant for CNC will cost the same as a New bare-boned PC with Windows 10.
    The new PC is the easiest path, as the DSP requires a lot of re-wiring!
  10. #1714
    Mar 2004
    LaGrange, GA USA
    Widget,
    Sorry to hear about the problems, but can't help you on either Mach or Windows! Good luck with whatever you come up with.
    Art
  11. #1715
    Jun 2005
    On Veterans Day, I ran across a plaque with an outstanding quote on it!
    So I decided to make a little plaque out of an 18" diameter panel!
    Big Red has become incredibly difficult to use; consequently, this will be the last plaque until I FIX Big Red!
    Happy Veterans Day to all !
    Attached Thumbnails Attached Thumbnails WidgitMaster's Largest Steel Router Table Project 9ft x 5ft x 8" Water Cooled Spindle-img_3261-jpg   WidgitMaster's Largest Steel Router Table Project 9ft x 5ft x 8" Water Cooled Spindle-img_3259-jpg   WidgitMaster's Largest Steel Router Table Project 9ft x 5ft x 8" Water Cooled Spindle-img_3258-jpg
  12. #1716
    Member cd_edwards's Avatar
    Sep 2011
    canada
    Default Re: Can anyone tell me if Mach3 will run on Windows 10?
    I run Windows 10 pro with both Mach3 and Mach4. I use a ethernet smoothstepper for control. Can't remember if you do or not. I don't think parallel port will work under windows 10.
    Colten Edwards [URL="http://www.cncsigns.ca"]http://www.cncsigns.ca[/URL]
