WidgitMaster's Largest Steel Router Table Project 9ft x 5ft x 8" Water Cooled Spindle - Page 141
Page 141 of 142 FirstFirst ... 4191131138139140141142 LastLast
Results 1,681 to 1,692 of 1695
Thread: WidgitMaster's Largest Steel Router Table Project 9ft x 5ft x 8" Water Cooled Spindle
  1. #1681
    Nov 2003
    manitoba, canada
    Default Re: WidgitMaster's Largest Steel Router Table Project 9ft x 5ft x 8" Water Cooled Spi
    The problem isn't really in the XY for me its in the depth. I installed hall effect switches with an Arduino to solve the home problem but your suggestion is great as well, not nearly as much work.
    I've noticed with a machine where you can't tell if the screws or rail is straight, you end up with accelerated thrust and radial bearing wear and even steel shavings inside of bearing housings. The depth isn't reliable for a multitude of factors my guess. But how can you adjust anything on the machine back to its true position without the machine sitting on a true position plane. You literally have nothing for a datum at all without the basic plane. You have trial and error which isn't fun.
    I've found the difference is 50-100 IPM between having a machine that stays lined up and one that has unknown problems inside of it.
    Just saying... you probably saved a lot of money and short term trouble doing it without epoxy though.
    I don't use ball screws either, I used ACME threads, and 3D printed nuts for them... this has been a very forgiving method for me considering the number of crashes the machine has been through.
  2. #1682
    Nov 2003
    manitoba, canada
    I feel like I'm picking on you haha and your router is far better than mine just know that years of fussing with mine has created a lot of frustration
  3. #1683
    Member widgitmaster's Avatar
    Jun 2005
    Quote Originally Posted by justCNCit View Post
    It’s a learning experience!
    Your next router will fix all your known problems, and create a list of new ones????
    I’ve made:
    30 Mini-Routers
    40 Midi-Routers
    12 Wide-Routers
    1 V-Rail Router
    2 Square Rail Routers
    1 Big Red monster!
    I’ve learned much in that journey!
    Widgit
    www.widgitmaster.com
    It's not what you take away, it's what you are left with that counts!
  4. #1684
    Jun 2005
    Merry Christmas to all!
    Yesterday, I chopped up all my scraps of yellow pine into 13 inch strips! Removing all the knots & cracks!
    Then I glued them together making 13" x 13" squares! Now I have the perfect gift for my closest Veteran Friends!
    The Laces were engraved with a 30 deg V-Bit!
    Attached Thumbnails Attached Thumbnails WidgitMaster's Largest Steel Router Table Project 9ft x 5ft x 8" Water Cooled Spindle-img_2794-jpg   WidgitMaster's Largest Steel Router Table Project 9ft x 5ft x 8" Water Cooled Spindle-img_2798-jpg   WidgitMaster's Largest Steel Router Table Project 9ft x 5ft x 8" Water Cooled Spindle-img_2799-jpg   WidgitMaster's Largest Steel Router Table Project 9ft x 5ft x 8" Water Cooled Spindle-img_2800-jpg
    WidgitMaster's Largest Steel Router Table Project 9ft x 5ft x 8" Water Cooled Spindle-img_2797-jpg   WidgitMaster's Largest Steel Router Table Project 9ft x 5ft x 8" Water Cooled Spindle-fb_img_1537731863827-jpg
  5. #1685
    Member Bubba's Avatar
    Mar 2004
    LaGrange, GA USA
    Merry Christmas to you also Sir. May you have a good one and look forward to the new year.
    Thank you for your service to the Country and to all of us on this board that look forward to seeing your work.
    Art
    Country Bubba (Older Than Dirt)
  6. #1686
    Jun 2005
    Quote Originally Posted by Bubba View Post
    Thanks Bubba!
    Here is the Source Files for the Memorial Plaque!
    VCarvePro ver 7.012
    Attached Thumbnails Attached Thumbnails WidgitMaster's Largest Steel Router Table Project 9ft x 5ft x 8" Water Cooled Spindle-img_2797-jpg
    Attached Files Attached Files
  7. #1687
    Member bill south's Avatar
    Apr 2005
    Great Work Widgit;
    Merry Christmas and here's hope for a wonderful new year!
    God bless you and our men in arms!
    Bill
    billyjack
    Helicopter def. = Bunch of spare parts flying in close formation! USAF 1974 ;>)
  8. #1688
    Nov 2003
    manitoba, canada
    Hey widgit can I ask did you pack all cables into the same cable carriers? That is, power cables and motor control cables/digital cables? Or was interference going to be a problem?
  9. #1689
    Jun 2005
    YES!
    All the cables are braided shields & stranded wires.
    They all have their shields grounded on one end, so all noise goes to ground.
    There is a fine bare-copper wire inside my dust tubes & pipes, which is also grounded on one end!
    I had the water cooling lines inside the wire tracks, now they run outside the tracks!
    When designing the electronics, I had purchased a spool of braided shielding, which allowed me to put all the single wires inside a braid & ground it!
    The shop vac has a metal canister, which sits near the computer. I had to connect a ground wire to it also, as the static was screwing up the computer!
  10. #1690
    Jun 2017
    Excellent work!!
  11. #1691
    Nov 2003
    manitoba, canada
    Quote Originally Posted by widgitmaster View Post
    YES!
    Forgive me for not going through all pages of the thread, were there pics or where did you source the shielding? Thanks
    nevermind... https://www.ebay.ca/itm/3M-Copper-Me...57cc%7Ciid%3A1
  12. #1692
    Jun 2005
    Here is a quick demo of how to make a shield for your wires!
    It was easier than searching for the right picture & thread!
    Attached Thumbnails Attached Thumbnails WidgitMaster's Largest Steel Router Table Project 9ft x 5ft x 8" Water Cooled Spindle-img_2881-jpg   WidgitMaster's Largest Steel Router Table Project 9ft x 5ft x 8" Water Cooled Spindle-img_2882-jpg   WidgitMaster's Largest Steel Router Table Project 9ft x 5ft x 8" Water Cooled Spindle-img_2883-jpg   WidgitMaster's Largest Steel Router Table Project 9ft x 5ft x 8" Water Cooled Spindle-img_2884-jpg
