Thanks, I see, bit of a difficult kinda shape to cover ! hope that goes OkOriginally Posted by ger21
There is no adjustment. Only on one end of one rail, because I needed a litttle bit of room to be able to get the rails through the end plates, as it's a very tight fit. The gantry and base torsion box ribs hold the pipes in place, and each is perfectly flat. (As flat as my 4 ft level, at least). There are threaded rods under the table holding the gantry sides tight to the rails.Originally Posted by Sanghera
UCCNC 2017 Screenset
I'm working on my Z-axis, which need some additional panels attached to keep if from flexing (design flaw ). The problem is, there is very little extra room to mount the panels, but I think I have it figured out. I only have room for 1/4" plywood, which is kinda flimsy, so I'm laminating some aluminum skins (.025) on to the 1/4" with epoxy. I'm going to throw them into my vacuum press shortly, so they'll be ready to cut and mount tomorrow.
In the meantime, I made a jig to turn the ends of my acme down with a router table. I bought some 1/2" ID bearings from Mcmaster Carr, as well as some 1/4" shank grinding stones. I set my router to 10,000 rpm, clamped the jig to the router fence, and fed it into the stone while turning it by hand. I'm using rollerblade bearings, so I need an 8mm shaft. I soon realised that grinding the 1/2" down to 8mm would take a loooong time, and if I got to aggressive, the screw got very hot. So, I pulled out the screw, and using my 12" disk sander, sanded all the threads off in about 1 minute. Then back to the grinding jig for basically a finishing pass.
Now, this is not an extremely precise setup, as fine tuning the fence turned out to be a bit tricky. Because of the lack of high precision, I had to end up a little on the small side, but I was able to get a very good fit. The ground area is within .001 it's entire length, .312-.313. 8mm is .3149, so I'm within .002-.003. And the tranition into the threads is radiused, so the bearing self centers. I then used an 8mm die to thread the end, and mount a nylon lock nut. The bearing will mount to the bottom of the screw, with the outer bearing in a 22mm counterbore under a 1/4" aluminum plate, and the top bearing resting on top of the plate. Here's a few pics.
Very inovative, you did an excelent job with what you had, now that something i would do
Joe
Ger
Very innovative solution to turning down the end of the acme threaded shaft. Thanks for the explanation & great photos.
I've been wrestling with a similar problem recently & this certainly helps.
Perhaps you could post a photo of the end of the shaft assembly as you explained.
Thanks, WT
Sorry if these are a little blurry.
Ger
Your bearing mounting technique should do the job quite well!
Thanks for the fast response.
WT
The X and Y axis will use the blocks I've shown earlier in this thread, Just the Z- is like that. All the screws will be done the same way.
Your router is very impressive. Some great ideas here, very innovative indeed.
Have you thought about buying a mini-lathe? They are reasonably priced, and are perfect for things like turning down shafts of leadscrews. I would not have been able to do half of my projects without it, including parts for my own router.
My wife would kill me if I bought a lathe. I don't like to buy cheap tools, so I'd probably end up spending a lot of money on one. I'll probably get one someday, but not in the immediate future.
Yea these little lathes do have their limitations. I would have saved up for a large one, but I have access to a 13x48 Clausing everyday. So for anything large, i just use that.
FOr hte price though, it cant be beat!
Got a little more done.
That's one stylish looking machine. Great workmanship !
Dang Gerry, you do good work!
Did those side plates on the Y carraige help? I'm guessing: yes.
What kind of motor couplers are you going with?
(BTW, my wife has killed me several times, really doesn't hurt that much after a while )
Steve
Nice Z axis!
Very nice work indeed, keep the pictures comming
Thanks, Joe
I liked how you wrapped the z carriage around.
If it's not nailed down, it's mine.
If I can pry it loose, it's not nailed down.
Have you noticed any skewing side to side on the gantry, I could see on some of the wider machines having problems if the bearings ride on only one side of the pipe so you only have a total of 8 contact points in 3D. It's something that I've been fighting in my design process. Best of luck the machine looks great.
Niiiice !! going to follow with interest - I've just m/c'd a Beam/plate for my m/c that will use two 20mm silver steel dia bars top n bottom, I'll have channel section on the back of a 10mm 1.3m long ally plate, still undecided about bearings tho.
Like it. keep posting
Pat
use two drive screws instead of one (Ok I'm talking Acme ones) - end of prob, at a price!Originally Posted by DDM
