Another First Router - Page 2
Page 2 of 13 FirstFirst 1234512 ... LastLast
Results 21 to 40 of 255
Thread: Another First Router
  1. #21
    Registered toolsalot's Avatar
    May 2003
    Forget the kitchen! Get out in that garage and start building.
  2. #22
    Gold Member High Seas's Avatar
    Sep 2003
    Malaysia/Australia/NZ/USA
    ger21 -
    At least the weather kept you outta the yard!
    I jackhammered and redid the driveway and walkway - cobblestone pavers - looks great but ohhhh my aching back!
    cheers - Jim
    Experience is the BEST Teacher. Is that why it usually arrives in a shower of sparks, flash of light, loud bang, a cloud of smoke, AND -- a BILL to pay? You usually get it -- just after you need it.
  3. #23
    Jan 2004
    Hopefully you didn't do what I did. I built all the kitchen cabinettes from scratch, and I didn't even have a cnc machine to help!
    I'm looking forward to seeing more pictures of your machine, especially since I have to design a new one for myself!!!
    Mike...
    P.S. Otherwise I'll just have to drive over to your house and check it out in person!
    Originally posted by ger21
    Hopefully I'll be back to work on it by June, maybe sooner. Just have to finish the kitchen.
  4. #24
    Member ger21's Avatar
    Mar 2003
    Shelby Township
    That's exactly what I did. The boxes have been done and installed for a while now. Except for 3, + an island. Mainly, I just have to cut and seam a bunch of veneer, press it in onto some mdf doors, dye and spray them. Oh, and build some pull out drawers, and numerous other small but terribly time consuming items.
    Mike, what happened to your router? Did all that flex make you decide to stop, or did you finish it?
    UCCNC 2017 Screenset
  5. #25
    Jan 2004
    Ger,
    I finished the router, and will use it for light cutting until I get a second one built. Do you have any pics of your kitchen. I'd love to see em. Since this is off topic, how about sending em here.
    mykes@comcast.net
    Mike....
  6. #26
    Member wjbzone's Avatar
    Apr 2003
    I would like to see them also. The General Wood Working forum might be a good place for pictures like that.
    Bill.
  7. #27
    Registered Patrick2by4's Avatar
    Feb 2004
    Hey Gerry, what happened to the thread, did you stop building your machine?
    -Patrick
    _____________________________________________
    measure twice, cut once - a good rule for everything
  8. #28
    Mar 2003
    Shelby Township
    I'm very slowly building a base right now, while I try to finish a bunch of other stuff I have going on. Should be able to get going again in about 2 months. I'll start a new thread when I get going again.
  9. #29
    Mar 2003
    Shelby Township
    After a long wait, construction has resumed! Everything in the previous pics was broken down and packed away for about a year. About a month ago I started reassembly. Here are a few pics of the gantry beam being assembled.
    Attached Thumbnails Attached Thumbnails Another First Router-gantry-beam-open-jpg   Another First Router-gantry-beam-closed-jpg
  10. #30
    Mar 2003
    Shelby Township
    Default Main Table
    Here is the main table framing. All the baltic birch parts I cut 2 years ago were still perfectly straight (they were wrapped with stretch wrap). I drilled a ton of holes to lighten up the framing. After a few I figured out that it was faster to leave about 1/16" from going all the way through, so I wouldn't have to keep cleaning the circles from the forstner bit. After sliding everything together, I layed it on my table saw and it was perfectly flat. This was important as the table holds the rails that the gantry rides along. Each side was then skinned with 1/2" mdf, stapled and polyurethane glued. (for more working time). Once the glue dried, I set the table on two sawhorses, and checked for flatness with a 4 ft level. Perfectly flat in every direction. And I have to put well over 100lbs of pressure on it to see any deflection.Table size is 59" x 32". Y axis travle will be the full 32", but that will be right up to the gantry uprights. X axis travel will be around 48".
    Attached Thumbnails Attached Thumbnails Another First Router-table-frame-open-jpg
  11. #31
    Gold Member Mr.Chips's Avatar
    Sep 2003
    Gilbert Az
    Welcome back Gerry.
    Good looking torsion box. It will be super strong too, as well as light.
    It does my old wood working heart good to see lots of wood in CNC machines. Not everything nas to be alum.
    Can't wait to see more pictures.
    Hager
  12. #32
    Mar 2003
    Shelby Township
    I wanted to build a sturdy base, without spending a lot of money. I bought a few 2x4's, and resawed them into ~3/8" x 3 1/2" strips. I then glued these up, jointed and planed them into roughly 2" x 4" legs. I drilled a hole in the bottom of each, and inserted a threaded coupler. I then made feet using this tip from Industrial Hobbies. http://www.industrialhobbies.com/how...hockeypuck.htm
    For about $6 for all 4, they work great. 1/2" mdf panels were mortised in to the legs to tie them together and stiffen everything up. ( the table does most of the stiffening, though). And on each end, a 3/4" baltic birch panel is mortised into the legs, and supports the table and tubing. The X axis steppers and leadscrews will also be mounted to these plates.
    I clamped everything toghether and took a few pics, with the gantry beam sitting on the table. This thing is pretty big. This weekend I'll get a coat of paint on it, and start on the gantry uprights. Hopefully everything will be rolling in a few weeks.
    Attached Thumbnails Attached Thumbnails Another First Router-full-frontal-jpg   Another First Router-3_4-view-jpg
  13. #33
    Mar 2003
    Shelby Township
    Quote Originally Posted by Mr.Chips
    Welcome back Gerry.
    Hager
    It's not that light due to the mdf. Next time, I'll use 3/8 or 1/2" baltic birch for the framing, and probably 3/8 baltic birch for the skins. It would probably cut the weight in half.
    I put all my weight on it (200+) with a level laying on the table, and it only sagged about 1/64". The entire gantry should be under 50lb, so It should stay perfectly flat. I was a little concerned with the 59"span, but it looks like it'll be OK.
  14. #34
    Sep 2003
    Gilbert Az
    That's right, I missed the MDF skins.. They are heavyweights. Did you do some of the cutting on a CNC?
    Hager
  15. #35
    Mar 2003
    Shelby Township
    Hager
    All the Baltic Birch pieces were CNC cut. I'm going to CNC a template for the gantry sides and use a pattern cutting bit to make them, hopefully this weekend.
  16. #36
    Sep 2003
    Gilbert Az
    Why are you pattern cutting? Is that because it is faster than to CNC them?
  17. #37
    Mar 2003
    Shelby Township
    Wer'e really busy at work right now, and I'll barely have time to CNC the template.
  18. #38
    Sep 2003
    Gilbert Az
    That's understandable. Being busy at work is a good thing.
    Hager
  19. #39
    Apr 2005
    Any updates on this? I'm particularly interested in how you are driving the X and Y axes.
    Jon
  20. #40
    Mar 2003
    Shelby Township
    No updates yet, although I've got the gantry uprights mostly assembled. X axis will have dual 1/2-8 2 start acme, same screw on Y axis. 253 oz-in PacSci steppers, 3 axis + single axis Xylotex (2-X, 1-Y, 1-Z)
    I doubt it will be as fast as I'd like, but that's all the budget allowed. I may upgrade to Geckos and a higher voltage power supply down the road.
