Originally Posted by
the_canuck
A few quick upgrades added to the machine.
Added a torque meter from the VFD. This will show if I'm pushing the spindle too hard.
Added a SSR to turn AC power on to the new AC outlet when the spindle turns on. It also has a manual override switch. I plan to use it to power on/off my shop vac dust collector.
Added an air solenoid to also turn on air to the mister when spindle turns on. This will keep the air compressor from running after the cut is complete.
With the new mods, I don't have to be so attentive to the machine when a cycle completes.
Messy wiring which I will clean up a bit but going for function over form as the wiring is inside the control box and reasonably protected.
Andrew
Sent from my SM-G965U using Tapatalk
