Mactec,
Looking good! You know, you could save yourself some machining time by just using double-stick tape to hold the rails on, and pistol drilling the holes for the ball screw end mount bearings.
Rob
Here is the start of a build for a friend
This machine will be able to cut around a piece of material 12x18 with up to a
1.00 dia cutter
It will have Hiwin linear rails & ballscrews
Motors & drives to be decided on, but most likely will be a servo system
We will try to do as much as possible, Using manual machines,(Time Permitting) to show the different setups, to make the parts needed to build this machine
Some of the material's needed in this photo
Mactec54
Mactec,
Rob
How big that rails?
spoiledbrat
If you look really close at the linear rails, that are in the photo they have no holes for mounting, so the the double sided tape, Is a great idea, & should hold them really well, As for a pistol drill, I'm sure it will get used
Mactec54
asuratman
The Hiwin rails in the photo are 20mm & will be for the X axes the Y & Z axes will have 16mm rails
Mactec54
Today we will set up the manual mill to start machining the base frame
This is a small Jet knee mill & was one of the first one's they sold, it has been a great little mill
First we will Tram the spindle, to get it true to the table, & then we can start to machine the parts for the base
The base frame is the most important part to get right, if this is not made well
it will affect a whole machine
Mactec54
The machining of the base frame, the aluminum pieces,were first deburred & then mounted on the mill & machined parallel
The 2 outside frame pieces, were milled for the linear rail mounting at the same time, The outside pieces are made from .750 Mic6 tooling plate
Mactec54
robe_uk
spoiledbrat & myself have a Joke about the double-sided tape & the pistol drill, as we were advised by a manufacture, To use this to fix his machine they had messed up on
It would be nice if there was a magical tape like this
Mactec54
Look at that immaculate workshop...
Have you ever done any work in there?
RomanLini
That's how all my machines look,The work tables of a machine is very important to keep them in great condition, If you want to hold tight tolerances on the parts you make
That machine is more than 10 years old, It is just a Standard Manual Jet knee Mill, no read-out, no power feed, (Just handles to crank) But I did fit a VFD, I have had servo motors on the X axes, but only for testing different motors
I usually just clean up the area of,(chips swarf oil Etc)before I take the photos, to make them look better
Mactec54
spoiledbrat
It's called a shop-vac it takes over!! I could lend it to you,It know's what to do, & does not need any training
Mactec54
"It's called a shop-vac it takes over!! I could lend it to you,It know's what to do, & does not need any training "
Probably has too many buttons to safely employ in this shop...
Rob
If my mills were that clean they would feel absolutely NAKED. They actually like having swarf and oil all over them.
CarveOne
CarveOne
http://www.carveonecncwoodcraft.com
For drilling, tapping, & reaming dowel holes in the ends of the frame rails, a fixture was made to mount on the side of the Mill table
The fixture was milled on the edges & then set up on the Mill table, the Key slot was cut
90deg to the edges of the aluminum plate, the holes were then drill, reamed for dowels & some of the holes were tapped
2 steel Keys were made for the mounting
With the fixture mounted on the Mill, the dowels were fitted down one edge & a stop at the bottom, it then has
2 Mitee-Bite clamps on the other side, to push & hold the parts up against the dowels, The ends were ready to get there holes done
There are 2 reamed holes & 2 tapped holes in each end
Mactec54
CarveOne
My machines would never feel naked, they are always making something,material being cut on them as well as losts of cutting oils Etc, The shop-vac sucks everything up for the photo shoots
Mactec54
CarveOne
If you need a lub,anti rust, try this on your machines or anything you want to use it on,Even for cutting/tapping it works quite well, This will solve your humidity problems on your machines, The humidity is not to bad here in TN
INOX Lube: inox-mx3 Multipurpose, Non-Toxic Lubricant
Mactec54
