I've posted this in a BC axis thread But to try and keep it all together I should post it here also.
I managed to get a few or things sorted with my BC head along with the rotating nut this last week.
Basicaly I' shortened the two axis to make it more compact,40mm on the C axis and about 30mm on the B
[IMG]
[/IMG][IMG]
[/IMG]
You can make out here how far the stepper is recessed inside the housing(the machined square in centre), this housing is mearly a means of connecting the two turntables at right angles to eachother.
[IMG]
[/IMG]
Machining the slots for bolts connecting the housing to the B axis turntable
[IMG]
[/IMG][IMG]
[/IMG]
A shot showing the housing upsidedown, harmonic drives and steppers bolted inside.
[IMG]
[/IMG]
The square attached to B axis is two pices of 12mm plate, one will be welded to the end of the 150 x 150 x 6mm RHS of the Z column, the other bolted to previous after machining for any error in alignment from horizontal in both planes.
[IMG]
[/IMG]
More on this as it progresses
Liam.
