- deskcnc foam position
Hi, I just started with deskcnc and mach3 to cut foam with Hotwire. Equal forms in the XY plane and the AB plane is working great. If the forms has a different size as a parallelogram his side. Than you have to indicate the position of the foam relative to the towers XY and AB. otherwise the size of the foam is not the same as the design. But I can not find how to indicate the foam position.
- You may not post replies
- You may not edit your posts
Forum Rules
