Newbie Foam cutter XY using DC motors with encoders
Results 1 to 6 of 6
Thread: Foam cutter XY using DC motors with encoders
    *Registered User* zeljo_bl's Avatar
    Jun 2018
    Default Foam cutter XY using DC motors with encoders
    Hello all, here is the story...
    I started to build CNC foam cutter, since I got hold of some parts from old machines I would like to try using them...cutter will have 2 X axles and 2 Y axles. Trying to use Maxon DC motors with HEDS-6310 208 B encoders from Mydata TP9. After encoder there is board with 74HC368D. Power supply line to motor have symmetric linear filter. Can Arduino handle all this in combination with some cheap drivers(lets say L298N)...
    encoder pinout attached...
    any hints are welcome
    Attached Thumbnails Attached Thumbnails Foam cutter XY using DC motors with encoders-encoder-jpg
    Registered jfong's Avatar
    Apr 2004
    https://www.youmagine.com/designs/dc...ware#!comments
    I tested this code a few years ago. It works for very basic brushed motor control.
    Uh,you produce foam?EPP or EPS?
    Jun 2018
    Default Re: Foam cutter XY using DC motors with encoders
    Quote Originally Posted by laser-machine-parts View Post
    nope, this is just hobby project to cut EPS foam...
    Jun 2018
    @jfong
    thanks a lot, any idea how to add slave motors?
    Apr 2004
    Just use multiple Arduinos/l298 and combine the step/direction lines.
    This will control 2 or more steppers from the same pulse.
