prebuilt cnc wire foam cutter machine recommendations
Results 1 to 2 of 2
Thread: prebuilt cnc wire foam cutter machine recommendations
    Jan 2018
    Default prebuilt cnc wire foam cutter machine recommendations
    Hello I would like recommendations on purchasing a CNC Foam wire cutter machine. I'm looking for a prebuilt version. Hotwirefoamfactory.com has some machines that look good. particularly the Sign Maker model seems like it would fit my needs.
    Is there any other company I should be looking at as well.
    thanks,
    Sep 2009
    Default Re: prebuilt cnc wire foam cutter machine recommendations
    Unfortunate you aren't getting any help. I was looking for the same thing.
    Tom
