Need Help! CNC GCode not following correct path
Results 1 to 2 of 2
Thread: CNC GCode not following correct path
    Nov 2013
    Unhappy CNC GCode not following correct path
    Hello everyone,
    Im stucked here without knowing how should I fix this error. I just built my Foam cutter CNC, I ran several small cuts in prior to test and calibrate machine, they came out pretty well, was really excited. But when I ran into a big sheet of polyestyrene, it came out in a really weird and unpleasing curves (you can see it in attached pictures).
    The software I am using is CorelDraw (SVG Export) -> DOCADO PathEdit to generate GCode -> Mach3 as the TB6560 controller.
    The only change I did to GCode, was to set a new start/origin in LazyCam and entered a new speed for the tool.
    Does anyone have any kind of idea what might be causing this?
    Thanks in advance!
    Attached Thumbnails Attached Thumbnails CNC GCode not following correct path-imagem-jpg   CNC GCode not following correct path-img_0260-jpg
    Attached Files Attached Files
    Nov 2013
    Default Re: CNC GCode not following correct path
    After a lot of research, I found out about the continuous mode of mach3, and learned the hard way about it. If anyone do get through this error after building the machine, I will leave the tip for solution I had to do: Just tune the motors acceleration to a higher one, so it will allow mach3 to work with CV. If you cant work out with a higher acceleration, disable the CV mode.
