- NEW BUILD Hot wire CNC Foam Cutter "Desktop" size
Reason: Wrong video
Re: NEW BUILD Hot wire CNC Foam Cutter "Desktop" size
Nice! This looks very impressive.
Reason: I accidentally posted this comment to another post. This isn't supposed to be here.
Hello, very nice Machine.
Iam begginin to build mine
What CAM software are you using for letters?
Are you using Mach 3?
Thanks for your reply
Hi!
Very nice machine, can you share a little bit information about heating the wire, how you control it. Where you buy this "brackets" that slide up /down and hold the wire, my guess 3D printing?
what software are you using to run it
have a look her https://www.rcgroups.com/forums/show...plete-Solution
lots of info there
- You may not post replies
- You may not edit your posts
Forum Rules
