Which is your favorite end mill for Alloy?
Results 1 to 1 of 1
Thread: Which is your favorite end mill for Alloy?
    Jun 2013
    Default Which is your favorite end mill for Alloy?
    I've been using Chinese endmills off Aliexpress for a while now with great results. These for the 4mm single flute hole making up to 10mm two flute extra long with a flute length of 45mm. All ok. Cheap.
    I also have been using some local supplied 8mm to 14mm 2 flute end mills. The 14mm I think is about my limit, any larger my machine might not be rigid enough. The 8mm 2 flute I have, has a 15mm flute length, with a wasted portion of the shank up to 50mm good for a deep cut but tends to sing a bit giving a slightly chattering finish on the side. If it was 10mm might be an improvement but I was just quoted NZ$150.
    Keen to know your favorite endmills you are using for alloy? I think for me something at 10mm with a decent bit of length would be nice. I am looking at spending around $100 so am keen to hear some advice or what works for you.
    I know all machines are different. Would be good all the same. Tell me which endmill you would shed a tear over if you crashed it into your vice jaws. B
    Sent from my SM-N970F using Tapatalk
    Oct 2023
    Default Re: Which is your favorite end mill for Alloy?
    Hello, we are manufacturer of cbn insert from China.
    We can give you advice about how to choose insert.
    We also do endmills.
    Welcome to enquiry.
    Whatsapp: +86-18282557341
    E-mail: john@meruitools.com
