Tool holder
Results 1 to 4 of 4
Thread: Tool holder
    May 2013
    Default Tool holder
    Can you just use a round pocket for a tool holder or does the standard holder help pull out the tool, BT30? Going strait down into the holder saves space and avoids conflicts with the dust boot. Thanks for the help, Edward
    May 2013
    Default Re: Tool holder
    I see that these are properly called tool forks not tool holders.
    Member CitizenOfDreams's Avatar
    Nov 2012
    The fork does not pull the tool out, the tool drops free when the spindle releases it. A straight down hole would probably work, but:
    1. You need to have some spring action so the tool could spring down 1-2mm.
    2. You need to have some breakaway parts in case something goes wrong during the tool change. A broken plastic fork is no big deal, a broken spindle is a disaster.
    Member machinehop5's Avatar
    Aug 2009
    ...aka Tool Gripper? :Claw, Fingers, Chop Sticks....
Tool holder
Tool holder
