Broaching unit for cnc lathe
Results 1 to 5 of 5
Thread: Broaching unit for cnc lathe
    Oct 2016
    Poland
    Default Broaching unit for cnc lathe
    Hi guys.
    I'd like to built my own broaching unit but I can't figure it out how this unit on retract move "drops" a small amount to avoid rubing.
    Any ideas? Drawings?
    Sent from my D5803 using Tapatalk
    Member rcheli's Avatar
    Nov 2005
    Default Re: Broaching unit for cnc lathe
    I think you will find what you are looking for here
    James on the Clough42 channel did a series where be builds a spindle lock, broaching bit, and writes code to do the broaching. I've built all the hardware for my mill but haven't tried it yet.
    Oct 2016
    Poland
    Hi, not exactly.
    I have done similar slotting already.
    But I'd like to speed it up by using broaching unit like Benz LinA or other manufacturers. They are pricey. $$$$
    Member deadlykitten's Avatar
    Jun 2015
    Antarctica
    hy, check attached / does it ring a bell ? i can help you with more specifics, like a simple sketch, toolholder organs dimensioning, talking about your desired approach, crafting tips, whatever you wish / kindly
    ps : drop amount has to be > turret radial feed among 1/2 M spindle turns multiplied by at least 20%, so to avoid friction even during high feeds; do the math this is why in that video, at 0:55, is said that max feed is 0.15mm/stroke, regardless of rpm value
    ps2 : x+ M spindle trigonometic, x- M spindle clockwise ... or viceversa
    we are merely at the start of " Internet of Things / Industrial Revolution 4.0 " era : a mix of AI, plastics, human estrangement, powerful non-state actors ...
    Oct 2016
    Poland
    Hi. Can you explain it, I don't get it.
    Jun 2015
    Antarctica
    this is for the "drop" behaviour; imagine such a cam, with the profile from the image from my previous post; the axis of this cam is coaxial with the M spindle
    Cylindrical Cam - YouTube
  7. #7
    Oct 2016
    Poland
    Do you know if the reciprocating action is made by conrod? have you seen one stripped? Have pictures maybe? Or could you sketch internal bits.
    Watched that cam video but still don't know how that works.
  8. #8
    Jun 2015
    Antarctica
    hy what do you mean by "reciprocating" ? what is a conrod ?
    no, but i have watched a few videos with different types of constructions
    pls check attached : is a rough "kinematic chain"
    it will take me a while, in order to draw a functional type / kindly
  9. #9
    Jun 2015
    Antarctica
    yes, z movement is done by a mechanism similar to a conrod
