Newbie How hot for a router bit?
Results 1 to 4 of 4
Thread: How hot for a router bit?
    Red face How hot for a router bit?
    HI
    I would like to know if my router bit is running too hot.
    My laser temperature meter shows that it is at 62 degrees centigrade (143 degrees Farenheit).
    This method of measuring the temperature of the bit might not give the true temperature of the metal, but maybe it is a good general guide.
    My bit is a 22mm plane making bit feeding at 100mm per minute. The meterial if MDF. I don't know what the rotational speed is.
    Thanks if anyone can advise.
    Dec 2013
    Default Re: How hot for a router bit?
    62°C does not seem too hot. At around 220°C I might get a bit concerned.
    Jim Dawson
    Sandy, Oregon, USA
    Member ger21's Avatar
    Mar 2003
    Shelby Township
    100mm is way too slow. Depending on your machine, you should probably be cutting at closer to 3000mm/min.
    62°C is not too hot, but it will be much cooler at higher feedrates.
    UCCNC 2017 Screenset
    Member Nadia556's Avatar
    May 2021
    Quote Originally Posted by ger21 View Post
    I have a similar issue with my hobbyist 2.2KW HP, could you give me some tips, I've lost a week on this problem. I haven't measured the exact temperature, but after only 200cm pass (4mm depth, 15000RPM, 1500mm/min, 2 flutes straight bit) it gets too hot to hold it for a few seconds. I tried cutting at 2000mm/min, also tried lower RPM - 10.000. It's not burning the wood (it only burns it at the bridges), and the bit is not getting cooler. Forgot to mention, I'm cutting 12mm plywood and max RPM is18000
