You will need to change the carousel fingers as well as change the height setting
As for what parameter it varies between controls so please advise model number
I am looking at a VMC that has a CT40 spindle and carousel/umbrella type toolchanger and a Fanuc control.
Problem is that I have BT40 tooling and would prefer to use it.
Is there an inexpensive way to change the toolchanger to make it hold BT40? I realize that I’d need to adjust the parameter for the tool change Z axis position (what parameter is this on Fanuc?).
