Any info on Escomatic machines Especially D6
Results 1 to 14 of 14
Thread: Any info on Escomatic machines Especially D6
    Feb 2006
    Default Any info on Escomatic machines Especially D6
    I am looking at purchasing an Escomatic D6 machine. Its probable around 30 Years old? IT's Cam driven
    They are a bit new to me. Anyone know what to look, problems, etc with these beasts.
    Ian
    Attached Thumbnails Attached Thumbnails Any info on Escomatic machines Especially D6-escomatic-jpg
    Registered BYTHEBOOKBOB's Avatar
    Aug 2007
    Default Escomatic
    The unique feature of an Escomatic is the ability to feed wire in coil form. The tools rotate as the stock is straightened and fed. For simple parts, you can attain high production rates and long runs. We just purchased an elderly D2 machine (5/32 in. capacity) and have learned quite a bit. The escomatic is a compact, robust mechanical marvel. The machines are cam driven though there are CNC models available. You will need cams for the stock feed and part profile as well as guide bushing, counter collet, custom ground form tools and straightener components. The tool head is the most critical component and can be quite costly to rebuild. Southwick and Meister (ph. 203-237-0000) can provide most of the parts you may need,or alternatively, you may get most anything you need as well as a wealth of information from Swisset Tool Company. (ph. 603-524-0082).
    Good luck.
    Mar 2004
    Groton NH USA
    Default Escomatic D6
    Hello
    Did you get your new / old Esco yet?
    Most older machines that have not been rebuilt recently may have some slop on the main shaft. Take ahold of the main shaft on the turret end (where the drills and collet are) and twist it back and forth. If you see that some of the shaft can move but not the other end near the feed cam (in front of the straightener) then you have some wear in the drive couplings.
    I have seen machines run for years with this slop but have also run into problems with the pressure on one cam where a tool or collet may be dropping out and a drill is going in on another cam, and the sudden jump of the shaft can break drills or leave steps on the part from the sudden movement.
    Other things that wear are the opening and closing of the feed and hold collets, this can lead to short parts. All of the items that wear are normal wear but quite expensive to replace.
    Look for areas that you have metal to metal contact and look for wear.
    Put a tool scope on the tool head and focus it on the bushing, take a wooden screwdriver handle and place it under the tool head and carefully lift the tool head up slightly to see if you can see play in the bearings through the scope.If you see it move more than the thickness of a line on the scope, you need bearings. You can also rotate it by hand looking through the scope and watch for movement.
    At least some of this will forwarn you what you may need to spend on the machine after you plug her in.
    And yes, Swisset Tool guys are great guys to deal with.
    www.scanalex.com
    Never Give Up
    Mar 2009
    france
    [I'm Specialiste Engineer for Escomatic Machine; Please contact with me to my E maill : dompye@wanadoo.fr
    I will help you for the D6 Esco Machine
    Best Rgds
    Dominique[/B][/COLOR][/COLOR][/COLOR][/COLOR][/COLOR][/COLOR]
    Nov 2010
    israel
    i recomend a supplyer from switzerland of parts cams and any other solutions for esco machines, his name is yves sedfi, whenever we need help, he served us.
    he is well connected and can get any machine or parts you need from any model the escomatic machines.
    his mail
    yvessedfi@bluewin.ch
    Feb 2011
    Malaysia
    Currently I have a supplier making small parts for me using a escomatic D6. However, he will no longer be able to make parts for me for some reason. Anyway, I am trying to find a new supplier and I was contacted by a factory using Citizen Auto Lathe? I have never heard of this machine but they guy said after seeing a drawing of my parts it can do it. My quastion is I know a escomatic can make my parts and to do so is not expensive, can the Citizen do the same?
  7. #7
    Oct 2008
    england
    Default Citizen vs esco
    If you have small batches of parts to make the citizen will do the job. I run both citizens and escos. A typical set up on an esco can take from 2-6 hours but it'll produce parts 10 times faster than a citizen! But the same job on a citizen could be set up and running in a fraction of the time. So if your batch quantities are in the tens of thousands the esco will win hands down. But if you're talking about small quantities of a few thousand or less the citizen will win. Hope this helps!
  8. #8
    Nov 2011
    españa
    We are a Spanish company that manufactures automatic and toll for 35 years if someone wants information phone the fax 0034.950.207081 0034.950.207082
    Email: infadecu@fadecu.e.telefonica.net
    Guaranteed quality polished with diamond toll microgram.
    We talked. Spanish, French, German and Italian
  9. #9
    Nov 2010
    uk
    I served my apprenticeship on Esco,s When qualified I ran 8 brand new D6,s in the shop we had 81 Escomatics !! great machines normal setup took 7 hours and I would change 2or 3 machines over every week ,I now run 4 sliders totally different kettle of fish ,I did love the D6,s though
  10. #10
    Jun 2012
    Default Chip and part separation
    We are looking for a better way to separate the parts from the chips as they drop off our Esco's. Any suggestions...
  11. #11
    Mar 2009
    INDIA
    I am having one Escomatic DS2 machine in good and running condition. I am now intrested to sell this machine. Anyone needs to see the photos of the machine can email me at steel_way@yahoo.com. The cost of machine is quite low just 4000 $ USD.
  12. #12
    Member Filipz's Avatar
    Mar 2019
    Default Re: Escomatic
    I recently bought Escomatic/Romatic DS2. But I am having so much trouble learning how to use it. Is there any online course that I can attend? Or would you know anyone in Europe perhaps who can teach me?
  13. #13
    Mar 2019
    Default Re: Any info on Escomatic machines Especially D6
    I recently bought Escomatic/Romatic DS2. But I am having so much trouble learning how to use it. Is there any online course that I can attend? Or perhaps you, or someone you know can teach me how to use it.
  14. #14
    Mar 2004
    Groton NH USA
    Quote Originally Posted by Filipz View Post
    Hello
    Those are not the easiest machines to learn for sure. Do you have a manual? The manuals are lousy but better than nothing. You can get a free pdf copy on my website.
    just go to scanalex.com and you can find the links from there. Good luck. If you email me direct, I can help you some, but due to time restraints it will be piecemeal here and there.
    escowizard@gmail.com
    Regards
    Scott
    Never Give Up
