Tool Holder material
Results 1 to 11 of 11
Thread: Tool Holder material
    Nov 2008
    Default Tool Holder material
    Looking to find out if anyone can tell me what type of steel is commonly used for the tool holders. We're looking to make our own to save some $$. Ideally a grade that's strong and rigid but would "give" in the event of an impact? Thanks!
    Jul 2005
    Hot rolled C1018, plenty strong enough but ductile enough to yield a bit if you bash it.
    You can also use cold rolled but depending on what machining is done on it a piece of cold rolled can distort as the rolling stresses are relieved.
    If you want easy machining use C12L14 it has a yield strength a bit below 1018 but is much easier to machine and, particularly, tap.
    Jan 2007
    MI. USA
    Commercial toolholders will normally be 4140, typically heat treated to 42Rc but just about any steel will work for low volume uses.
    Milling cutters are often made from 4140 pre-hard because they warp too much in heat treat.
    Bob
    You can always spot the pioneers -- They're the ones with the arrows in their backs.
    Registered mc-motorsports's Avatar
    Feb 2007
    Yep, 4140, the ones I make are made from prehardened material 36-38 Rc, lathe tool holders.
    Jul 2005
    Quote Originally Posted by CarbideBob View Post
    Bob
    The bolt on tool holders and boring bar holders on Haas machines are definitely not 42Rc and they do not machine like 4140. Similarly all the tool holders on the manual machines I used to have were all non-hardened low or medium carbon steel. Milling holders are a different thing they are hardened and ground.
    Nov 2008
    I suppose it might depend on the tool holder application but some people feel that the type of steel should be able to "give" in case of an impact and not be too hard that it could damage the carriage or spindle. Any thoughts?
  7. #7
    Jul 2005
    I think there is some validity in the 'give' idea. The peak forces involved in stopping something over distance of 0.01" are ten times what occurs if something is stopped over a distance of 0.10". I think the 'give' displayed in this picture may have helped save my spindle bearings in a recent crash, my worst ever.
    http://www.cnczone.com/forums/attach...0&d=1210645888
  8. #8
    Nov 2008
    Nice illustration Geof, I was probably not specific enough in my original question as it might be different in my case... The "tool holder" I was refering to is one where you'd bolt on a carbide bit and then place into the machine. It may be reffered to as the "shank"? We've been buying these from Mitsubishi to use in our screw machine gang posts.
  9. #9
    Feb 2007
    Quote Originally Posted by Geof View Post
    I don't think he means a "tool holder" in the respect your refering to, more of a tool post. I think he means more of an insertable turning tool. 4130 36-38 Rc, prehardened, the pocket flatness and angles are critical depending on the insert being held.
    Attached Thumbnails Attached Thumbnails Tool Holder material-h8287-jpg
  10. #10
    Jan 2007
    MI. USA
    Toolholder mounts or "nests" and bushings are harder so they won't wear.
    6150 or 8620 somewhere in the low 60's Rockwell.
    Insert holders will range for 32-48 Rc depending on who yet get them from.
    Different mfgs have differing specs. One advantage to the softer holders is that you can easily cut them to length on a a bandsaw.
    Bob
  11. #11
    Member Syoung576's Avatar
    Nov 2020
    Default Re: Tool Holder material
    Can anybody tell me if you can use Bronze for a tool holder?
