Hi Cbayram7,
I don't know if you can change the start position by parameter, but I don't think that is actually the reason that Z2 is moving at the beginning of your cycle. The Z2 movement is being caused by your mode change. I'm guessing you have a G600 or G630 at the top or bottom of your program (or another mode change). When the G600 mode is called the turret moves to the forward "home" position (close to the guide bushing) as part of this mode change, when the G630 mode is called the turret moves to the back "home" position. At mode changes you can add the W0 argument in $2 and that will keep your turret where it currently is (i.e. G600W0 or G630W0). Hope this helps.
