If I'm correct you're using a .015R insert, I would suggest running the smallest nose radius you can get away with. Larger nose radius will increase contact area leading to the material "pushing off" or deflecting. I've had this issue in the past in softer stainless on parts with a thin wall I need to hold .0005" roundness on the ID, the larger nose radius was giving me out of roundness which transferred over into the ID, switched to a .004R insert and they're almost perfect now. The only other thing you can do is run an extended land guide bushing, split up the turning, use the sub as support and use a back turning tool, though, I'm not sure you can get a guide bushing that long.
If you figured it out already would you mind telling us what you did to fix it?
