- C-axis engage/cubic diamond csl HELP!
Im working with a / cubic diamond csl- with polygim controls. Meldas 60 series.
After a battery failure, machine had to be reprogrammed. I can engage c axis via panel, but not through program.
When moving C with
G00 C90. The servo spins but c does not engage. I can disengage after engaging with panel using M92 but i cant seem to engage in program. Am i missing something?
Tried M93,M90,M91. Thanks a ton!
- You may not post replies
- You may not edit your posts
Forum Rules
