hi, i am afraid that this does not happen ... there is a play between the " id holder of the machine" and "sleeve that holds the tool" + other playsthe piccco cut and the correct holder should put the tool on center
this play is not extraordinary big, but it still allows to put&remove the sleeve by hand, without too much effort, and so, the screws will tend to tilt a bit this sleeve, so missaligining will increase on tools with long overhang ... things simply sum up
i just saw that there are even smaller piccos ( attached )
hmm, maybe there is a method for aligning such tiny stuff / kindly
