please, how to check alignment for small tool ... - Page 2
Page 2 of 2 FirstFirst 12
Results 13 to 20 of 20
Thread: please, how to check alignment for small tool ...
  1. #13
    Member deadlykitten's Avatar
    Jun 2015
    Antarctica
    Default Re: please, how to check alignment for small tool ...
    hy thunder, please, i have seen that you have an extra-sense when it comes to alignments; please, can you help me with this one ?
    https://www.cnczone.com/forums/gener...lign-long.html
    kindly
    Ladyhawke - My Delirium, https://www.youtube.com/watch?v=X_bFO1SNRZg
  2. #14
    Mar 2009
    us
    I'll bet it's pricey, but well worth the money if you constantly deal with small tooling...
    https://www.genswiss.com/perfect-zero.htm
    Youtube video of system here...
  3. #15
    Jun 2015
    Antarctica
    nice tool / thx
  4. #16
    Jan 2013
    What you want to get is the picco ace holder I have linked here It requires a quarter turn to seat or realease the insert.
    Alo in my opinion the Genswiss is not accurate enough. It is an interesting idea, but must not accurate enough to justify the purchase.
  5. #17
    Jun 2015
    Antarctica
    hy jreynolds that thing from iscar is good 2 clamp the tool, but is not assuring coaxiality; only a sleeve and a cnc do not assure coaxiality, but a measuring & adjustment method
    Also in my opinion the Genswiss is not accurate enough
    somehow i also feel that; even if there is low tir when the device is clamped inside the guide bush ( and guide bushes are wear parts, etc ), also the camera has to be concentric with the od of the part, and i don't know how is possible to check that
    however, i was wondering if there is a variant to home-build such gadget i am not up2date with latest stuff, but i believe that a small camera concentric with the housing + wireless transmission, is not hard to find these days / kindly
  6. #18
    Jan 2013
    you could always blue the end of your stock and bring up the tool and scribe it with the tool then remove the stock and look at it. I have never really founf that the be a big issu.
  7. #19
    Mar 2009
    us
    Quote Originally Posted by jreynolds5 View Post
    What are you talking about? The Genswiss system can center the tool within TENTHS RELIABLY. You say it's not accurate enough, yet go on giving advice of blueing the end of the bar and scribe a line? LOL
  8. #20
    Jun 2015
    Antarctica
    hi 369, to eliminate doubts, it is required to check :
    ... the alignment of the genswiss system; the camera center is coaxial with the housing ? they are never coaxial, so is needed to measure the excentricity, so to determine the precission class
    ... the resolution; that's easy
    TENTHS RELIABLY
    2.33 tens, or 0.7tens ?
    1.1 or 0.15 tens ?
    also, what does those numbers represent ? and how to check these numbers ?
    is not only about scribing the line, but also inspecting the scribbed line position with instruments with precision <0.01, like microscopes, etc
    this method takes longer than using the genswiss, but is possible to determine their precision pretty accurate
    a microscope acurracy&alignment can be checked, so it can be trusted, but it requires time to use it; to shorten that time, is easier to put the microscope/camera inside the cnc, but this 'alternative' also needs to be checked for accuracy & alignment ... at this moment i don't know how is that possible, so to make the device trustfull / kindly
