You can't rotate a live unit and still use the ID stations on an A20. Or on the A32's - unfortunately! ------------------- John
Has anyone ever added a double spindle right angle live tool to there A20 and if are you still able to use the 4 position drilling station and your back spindle block or is there to much interference.
hi jimwjr, i was told that it is possible for L12, but i can't tell for a20, so i searched a20 on youtube ... put the nose of the id tools at same Z like the od tools, and the 90* live-holder far back, near the id-tools. use long sleeves ?
i can't help for a20, because i don't know where the interference is, but maybe there is a way arround / kindly
we are merely at the start of " Internet of Things / Industrial Revolution 4.0 " era : a mix of AI, plastics, human estrangement, powerful non-state actors ...
Do you have a pic of the live tooling block your speaking of.
We have dual spindle live blocks for our A20’s. It adds tool numbers 16 and 17. I think
hi jim, i don't have a live holder @ 90*, but i talked your situation with my citizen dealer, and he said that putting the live holder far back, like in attached image, should work without worries .... who is interfering with who ? kindly
hi jim, when i talked with my dealer, it was not clear to me what collision is there, but now i understand, and yes, i believe that a collision may occure
i can't check, but, what about using a multi-holder ?
if you lose those 4 posts for spindle 2, maybe you can add them on the back of the T11-14 ? check attached images, and, if you wish, pls consider crafting those 'dual' holders, buying them etc ... i hope there is enough room inside the cabinet / kindly
