- Need Help!- IEMCA Boss 332 protected parameters access
Just received the machine Citizet L20 + IEMCA 332 bar feeder and aligned both parts to each other. As I can see from the manual I need to correct some distances in the protected parameters after installation.
Can anybody help with access code to modify protected part?
Thank you in advance!
- You may not post replies
- You may not edit your posts
Forum Rules
